    [Plugin] Reports coordinates of a cpoint
    7 Posts 3 Posters 9.2k Views 3 Watching
    • M
      mmyoung
      Does anyone know of a Ruby that would report the coordinates of a construction point when it is selected? Would be very helpful in DTM work. Thanks
      Michael Young
      Albuquerque
      OSX; SketchUp, Vectorworks, and Wings3D
      (which play nicely together)
      • TIGT
        Here...
        Copyright 2010 (c), TIG
        All Rights Reserved.
        THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
        WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
        cpointtext.rb
        This tool adds a piece of text with a leader to any selected Cpoints
        [guide-points].
        It is shown thus [0, 123, 4567].
        The numerical values reflect the 'precision' of the model's units
        settings - in the example above it's 0 - typical for 'mm' model.
        If it were a 'meter' model then the precision might be 3, giving
        [0.000, 0.123, 4.567].
        To use it Select some Cpoints [other things selected will be ignored].
        Type cpointtext in the Ruby Console to run it...
        It's other use is to draw a Cpoint at a given 3d-point, to do this type
        in the Ruby Console 'xyz' values or an actual point thus:
        cpointtex 1,2,3.4 or cpointtex(1,2,3.4)
        or
        cpointtext [1,2,3.4] or cpointtex([1,2,3.4])
        or
        cpointtext point3d or cpointtext(point3d)
        or
        cpointtext vertex3d or cpointtext(vertex3d)
        Note the space between the cpointtext and the first argument OR the
        parentheses enclosing all arguments without a gap before the (
        cpointtext(x,y,z) - this is the safer option.
        You call this method from within other commands.
        Units are in current units - i.e. inches, feet, mm, cm or m.
        It draw a cpoint at that point's location with associated text...
        Donations:
        Are welcome [by PayPal], please use 'TIGdonations.htm' in the
        ../Plugins/TIGtools/ folder or PM @TIG...
        Version:
        1.0 20100409 First release.
        1.1 20100411 If 3 arguments/array [x,y,z] draws cpoint+text, gsub! fixed.
        1.2 20100412 Argument can also be a 'Point3d' or 'Vertex3d'. Now undoes.
        Put this file into the Plugins folder and restart SketchUp...
        • M
          mmyoung
          TIG:
          Brilliant. Thank you so much. This is saving my cookies.
          And I love my cookies!
          Michael Young
          Albuquerque
          • TIGT
            Version 1.1 now available http://forums.sketchucation.com/viewtopic.php?p=238662#p238662
            Fixed a glitch with gsub! sometimes not reporting location correctly, and it now has option to take 3 arguments or an array [x,y,z] to add a cpoint and text...
            • M
              mmyoung
              Ah! Thank you so much.
              If any of you are not using SkUp for DTM work,
              now you have no excuse!
              Michael Young
              Albuquerque
              • Chris FullmerC
                whats dtm.
                All my Plugins I've written
                • TIGT
                  Here's another update v1.2 http://forums.sketchucation.com/viewtopic.php?p=238662#p238662
                  It now lets you pass a Point3d OR a Vertex3d as an argument as well as in raw x,y,z values or an array [x,y,z].
                  Now has one step undo for plain cpoint texting...
                  You can call it from other scripts so for example you could read a number of points an array of them, or say vertices from faces...
