    [Plugin] Reports coordinates of a cpoint
    7 Posts 3 Posters 8.8k Views 3 Watching
      mmyoung
      Does anyone know of a Ruby that would report the coordinates of a construction point when it is selected? Would be very helpful in DTM work. Thanks
      Michael Young
      Albuquerque
      OSX; SketchUp, Vectorworks, and Wings3D
      (which play nicely together)
      • TIGT Online
        Here...
        Copyright 2010 (c), TIG
        All Rights Reserved.
        THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
        WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
        MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
        cpointtext.rb
        This tool adds a piece of text with a leader to any selected Cpoints
        [guide-points].
        It is shown thus [0, 123, 4567].
        The numerical values reflect the 'precision' of the model's units
        settings - in the example above it's 0 - typical for 'mm' model.
        If it were a 'meter' model then the precision might be 3, giving
        [0.000, 0.123, 4.567].
        To use it Select some Cpoints [other things selected will be ignored].
        Type cpointtext in the Ruby Console to run it...
        It's other use is to draw a Cpoint at a given 3d-point, to do this type
        in the Ruby Console 'xyz' values or an actual point thus:
        cpointtex 1,2,3.4 or cpointtex(1,2,3.4)
        or
        cpointtext [1,2,3.4] or cpointtex([1,2,3.4])
        or
        cpointtext point3d or cpointtext(point3d)
        or
        cpointtext vertex3d or cpointtext(vertex3d)
        Note the space between the cpointtext and the first argument OR the
        parentheses enclosing all arguments without a gap before the (
        cpointtext(x,y,z) - this is the safer option.
        You call this method from within other commands.
        Units are in current units - i.e. inches, feet, mm, cm or m.
        It draw a cpoint at that point's location with associated text...
        Donations:
        Are welcome [by PayPal], please use 'TIGdonations.htm' in the
        ../Plugins/TIGtools/ folder or PM @TIG...
        Version:
        1.0 20100409 First release.
        1.1 20100411 If 3 arguments/array [x,y,z] draws cpoint+text, gsub! fixed.
        1.2 20100412 Argument can also be a 'Point3d' or 'Vertex3d'. Now undoes.
        Put this file into the Plugins folder and restart SketchUp...
          mmyoung
          TIG:
          Brilliant. Thank you so much. This is saving my cookies.
          And I love my cookies!
          Michael Young
          Albuquerque
          • TIGT Online
            Version 1.1 now available http://forums.sketchucation.com/viewtopic.php?p=238662#p238662
            Fixed a glitch with gsub! sometimes not reporting location correctly, and it now has option to take 3 arguments or an array [x,y,z] to add a cpoint and text...
              mmyoung
              Ah! Thank you so much.
              If any of you are not using SkUp for DTM work,
              now you have no excuse!
              Michael Young
              Albuquerque
              • Chris FullmerC Offline
                whats dtm.
                • TIGT Online
                  Here's another update v1.2 http://forums.sketchucation.com/viewtopic.php?p=238662#p238662
                  It now lets you pass a Point3d OR a Vertex3d as an argument as well as in raw x,y,z values or an array [x,y,z].
                  Now has one step undo for plain cpoint texting...
                  You can call it from other scripts so for example you could read a number of points an array of them, or say vertices from faces...
