    'Intersect' Leaving Strange Holes when Used With Curved Surf
    4 Posts 2 Posters 327 Views 2 Watching
    • Tim DanaherT
      Tim Danaher
      I'm trying to use 'Intersect' to create some stencil text on the back of this bloody iPod cover. However, when I hide the cutting group, there are all sorts of holes left over, and what's more, I can't repair them -- they never fill in, even using Triangles...
      Is the iPod cover so badly formed, or is there something else...?
      TIA,
      Logo_Cutter.skp
      Cheers,
      Tim
      http://vizarch.blogspot.com
      • GaieusG
        You know the answer:
        Subject: Why Can't I Sweep this Profile Around this Curve?
        @jim said:
        It's too small. Scale it up and try it.
        πŸ˜‰
        Logo_Cutter.skp
        • Tim DanaherT
          Tim Danaher
          Seriously?
          And here's me trying to impress upon my students that they should always model at scale...
          Cheers,
          Tim
          • GaieusG
            There are exceptions and if an exception has its meaningful explanation, the students should understand and accept those exceptions.
            After the intersection and clean-up, you can safely scale the model back (like I did in the attached file). This won't contradict with the "general rule" either as you end up with a 1:1 scale model just have used a trick to come around an OpenGL limitation.
