    'Intersect' Leaving Strange Holes when Used With Curved Surf
    4 Posts 2 Posters 266 Views 2 Watching
    • Tim DanaherT Offline
      Tim Danaher
      I'm trying to use 'Intersect' to create some stencil text on the back of this bloody iPod cover. However, when I hide the cutting group, there are all sorts of holes left over, and what's more, I can't repair them -- they never fill in, even using Triangles...
      Is the iPod cover so badly formed, or is there something else...?
      TIA,
      Logo_Cutter.skp
      Cheers,
      Tim
      http://vizarch.blogspot.com
        You know the answer:
        Subject: Why Can't I Sweep this Profile Around this Curve?
        @jim said:
        It's too small. Scale it up and try it.
        πŸ˜‰
        Logo_Cutter.skp
          Tim Danaher
          Seriously?
          And here's me trying to impress upon my students that they should always model at scale...
          Cheers,
          Tim
            There are exceptions and if an exception has its meaningful explanation, the students should understand and accept those exceptions.
            After the intersection and clean-up, you can safely scale the model back (like I did in the attached file). This won't contradict with the "general rule" either as you end up with a 1:1 scale model just have used a trick to come around an OpenGL limitation.
