    Free upgrade to the latest version....
    renderpluginsextensions
    28 Posts 4 Posters 5.8k Views 4 Watching
    • A
      arjunmax09
      i have vray 1.05.30....full version. .. now i downloaded 1.48.66 from asgvis website... i heard on this forum that if you have an older version of vray you get a free upgrade to 1.48.66....well this isn't actually the thing with me...i've installed vray 1.48.66 and when i press the render button...nothing happens πŸ˜’
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • thomthomT
        There some issues with the latest version where it some times won't render. They are working on a patch. There is a few threads over at ASGVis on the topic. You will also find a couple of sticky forum threads there from the developers about using the debug menu and also how to send them an error report.
        Many of the issues appear to be related to materials.
        • A
          arjunmax09
          just a simple box with the default material won't render....in fact the render doesn't even start in a blank file... πŸ˜’
          btw...is your vray 1.48.66 going fine....?? and is there really a free upgrade or i'm mistaken?? πŸ˜’
          • thomthomT
            Yes - my 1.48.66 is working. The upgrade is free. But there are some people that experience issues that prevent rendering from happening.
            Check the Ruby Console for errors (open it before you hit render) And check the VfSU error log. (There's a sticky at ASGVis where you can find it.)
            Btw, did you uninstall the old one before installing the new one? The new one won't automatically uninstall the previous version and will cause conflict.
            • A
              arjunmax09
              no... i didn't as far as i remember because when i uninstalled the newer version i didn't have to install the previous version....the previous version automatically came back.....I guess that's how the upgrade is going to work...Did you uninstall the previous version before installing the new version??
              If we want to upgrade from xp to vista we don't have to uninstall xp do we?? we just straightaway install windows vista....all our data and settings remains safe....that's why i didn't uninstall the previous version...
              • thomthomT
                The latest version of VfSU requires you to uninstall the previous. Other software might not require you to do so, but this version of VfSU does.
                • A
                  arjunmax09
                  so it automatically detects that we want to upgrade or does it asks for a license file??
                  • thomthomT
                    Uninstall the old
                    Install the new
                    It should detect your old license as that is not uninstalled.
                    • A
                      arjunmax09
                      eh....that's the license doesn't uninstall yeah??? πŸ˜’
                      • thomthomT
                        Yes.
                        When you uninstall V-Ray the license is not uninstalled. So when you install V-Ray again (no matter what version) it should detect your old license.
                        • EarthMoverE
                          EarthMover
                          I've never manually uninstalled any version to update. The installer has done the uninstall for me and I've had no problems.
                          Content Creator at Skapeup
                          • thomthomT
                            I think previous versions uninstalled older versions automatically. But with 1.48.66 that changed. I think they changed installer - and it does not detect older versions. And having both installed will cause conflict.
                            With the new version you should have only vfs.rb in you SU plugins folder. Any other V-Ray references means you have remains of the old and will cause conflicts.
                            • EarthMoverE
                              EarthMover
                              This is what I get.....
                              • thomthomT
                                whut whut? hm... maybe they changed the installer...
                                well, I stand corrected.
                                But if you do experience problems, do check that the previous was uninstalled. there has been some cases at ASGVis forum where people had problems because the old was not uninstalled.
                                • thomthomT
                                  hmm... was that 1.05.30 that was detected, or was it an older beta?
                                  • A
                                    arjunmax09
                                    i'd like to post something here that i forgot... the installation gives a message that the setup itself has to abort as it's causing conflict with the setup itself!!! like... often while installing programs the setup asks us to close internet explorer, firefox, etc... this setup was really different .. i mean it was asking to terminate itself!!! πŸ˜† !
                                    • thomthomT
                                      😲 πŸ˜•
                                      I'd say that is one you should let ASGVis know.
                                      • A
                                        arjunmax09
                                        alrighty.....i uninstalled the previous vray version. the installation of 1.48.66 went smooth....but vray did not detect my existing license and is still asking for one.....if i load the old license it doesn't detect it.... πŸ˜’ please help
                                        • thomthomT
                                          Not sure why that is.
                                          • thomthomT
                                            Re-entering your license info should work though. If that doesn't work you need to ask ASGVis.
                                            • 1 / 2
