    Free upgrade to the latest version....
    renderpluginsextensions
    28 Posts 4 Posters 5.8k Views 4 Watching
      Yes.
      When you uninstall V-Ray the license is not uninstalled. So when you install V-Ray again (no matter what version) it should detect your old license.
      • EarthMoverE
        EarthMover
        I've never manually uninstalled any version to update. The installer has done the uninstall for me and I've had no problems.
        Content Creator at Skapeup
          I think previous versions uninstalled older versions automatically. But with 1.48.66 that changed. I think they changed installer - and it does not detect older versions. And having both installed will cause conflict.
          With the new version you should have only vfs.rb in you SU plugins folder. Any other V-Ray references means you have remains of the old and will cause conflicts.
          • EarthMoverE
            EarthMover
            This is what I get.....
              whut whut? hm... maybe they changed the installer...
              well, I stand corrected.
              But if you do experience problems, do check that the previous was uninstalled. there has been some cases at ASGVis forum where people had problems because the old was not uninstalled.
                hmm... was that 1.05.30 that was detected, or was it an older beta?
                  arjunmax09
                  i'd like to post something here that i forgot... the installation gives a message that the setup itself has to abort as it's causing conflict with the setup itself!!! like... often while installing programs the setup asks us to close internet explorer, firefox, etc... this setup was really different .. i mean it was asking to terminate itself!!! πŸ˜† !
                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    😲 πŸ˜•
                    I'd say that is one you should let ASGVis know.
                      arjunmax09
                      alrighty.....i uninstalled the previous vray version. the installation of 1.48.66 went smooth....but vray did not detect my existing license and is still asking for one.....if i load the old license it doesn't detect it.... πŸ˜’ please help
                        Not sure why that is.
                          Re-entering your license info should work though. If that doesn't work you need to ask ASGVis.
                            arjunmax09
                            i just import the asgvlic file ... what is the information to be entered??
                              You get a window asking for registration info, right?
                                arjunmax09
                                Yes I do get a window having three options.. i don't remember right now... but maybe they are the following
                                I have a standalone license server
                                I have a commercial license
                                I wish to demo this product..
                                  That's the one. Choosing that should ask you for your license info.
                                    arjunmax09
                                    then i use the old activation key that i had but it doesn't activate saying that there's a failure or something like that.....do i need a new asgvislic license file??
                                      VfSU generates the license file on your computer - you don't have to deal with the file yourself. You should only need to enter your registration info.
                                      Not sure what's going on.
                                      Contact authorizations@asgvis for support.
                                        arjunmax09
                                        I import the old license file that was sent to me for vray 1.05.30
                                        What is registration info like serial key or my name and everything
                                        • dkendigD
                                          dkendig
                                          arjunmax09 - Please contact the appropriate support channel so you can actually have your issue resolved. This is not the ASGvis forums, nor an official support channel. You are experiencing an issue that can not be resolved by anyone other than ASGvis.
                                          Devin Kendig
                                          Developer
