    Corner Cubby
    42 Posts 12 Posters 5.4k Views 12 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Hi Guys,
      It's been quite a while since I posted any work. I have been looking for a workstation that would fit in neatly to a living / dining rm corner. The area available is just over a meter square.
      I thought I'd find something at IKEA but was not impressed with their ALVE Corner workstation (pic below) but liked the price πŸ˜‰ So I set about designing something that would address my needs. The brief was,
      a. Has to fit into an area of 1 meter squared.
      b. The seating position has to be parallel with the walls. I did not want to be looking at a corner.
      c. Some kind of a privacy screen would be desirable.
      d. Plenty of storage and desk space.
      With the initial design, which I call the Corner Cubby, I have addressed most of the above requirements.
      The next step is to figure out an inexpensive way of putting the unit together. I have a friend with a woodwork shop that will do the job for me. I just need to source the materials and fittings. The attached PDF explains the fabrication process.
      Any comments welcome before I go much further.
      Mike
      Corner Cubby.pdf
      • dermotcollD Offline
        dermotcoll
        Mike - it looks good - I would advise at least 500mm of space where u are working on a keyboard / screen as you need a bit of space. i did not download your model yet but everything looks good - rule about 1m2 space is a little bit of a cheat if you are using the rolling cart as part of the set up!!!
        edit - just downloaded the pdf and can see that it stores in the knee space when closed!
        Hafele Ireland, based in Wicklow, will have everything you need for the project - your friend will need to have an account to get the stuff - trade only - or if you need it , I can get it. B&Q, ATlantic homecare or the other Irish hardware stores will have some of the stuff but not all of it.
        PM me if you want ot discuss further.
        When you burn your arse - you gotta sit on the blisters!!
        • chrisglasierC Offline
          chrisglasier
          Mayoral Tardis?
          With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
          • RichardR Offline
            Richard
            Mate it is all darn tight in there! I can imagine some swearing when the knees hit!
            almost a shame the chair doesn't host somewhere within the fabric of the cabinet!
            BUILTBRAND.COM.AU
              Mike Lucey
              Thanks for the leads Dermot. I will check them out. I squeezed in a 500mm lead desktop and a 425mm 'elbow' layout area. So probably would be enough room. The mobile Storage unit can also offer extra layout space if rolled out, although it can remain under within the Cubby at still have access to the two drawers and file. Its cheating the brief a bit by having it as a roll out but as long as it can be tidied away that's okay.
              Chris, πŸ˜† 'Time And Relative Dimension In Space'! Would hope so πŸ‘
              Hi Richard, I would hope that there would not be too much knee banging at all πŸ˜„ I actually designed the unit around the Jules desk chair http://www.ikea.com/gb/en/catalog/products/S29856865 as it had a flat back. I wanted to be able to store a chair within the unit when closed and the Jules was the best I could find for this job.
              Talking about fabric! I propose to use some sort of semi transparent fabric on the folding doors and side panels (not back ones) as it will keep the doors lightweight and also allow some light / visibility when in the 'privacy position'.
                chrisglasier
                Will you be setting it to go back in time to show it to Richard?
                  Mike Lucey
                  πŸ˜† It's on its way!
                  • stefanqS Offline
                    stefanq
                    Just a small suggestion, if I may....I would move those shelfs above the monitor.
                    • N Offline
                      notareal
                      I see one possible issue with ergonomics; the left arm and the right arm will have different support.
                        Mike Lucey
                        Stefanq, Yes, good suggestion. It would look less 'busy'.
                        Notareal, As I have shown it there is no support for the left arm really. This suits me as I am right handed and just need the mouse area on the right. I can keep my left hand in my pocket πŸ˜‰ The design is totally reversible so could suit a left handed person also. The shelves mentioned by Stefanq can also be on either side as they will fit either way.
                        Thanks for all the feedback, much appreciated πŸ‘ This is something I miss over the past couple of years since semi retiring and working by myself.
                        • charly2008C Offline
                          charly2008
                          Hi Mike,
                          a beautiful design and a good idea. I would give up the sideboard, which disturbs the harmony. Instead, I would extend the two ends for a little storage space.
                          Karlheinz
                            Mike Lucey
                            Karlheinz,
                            You have hit the nail on the head ... 'disturbs the harmony'! I find that a lot of home workers, especially in open-plan living areas, often are under pressure to keep their office work space nice and tidy! Personally I am a slob when it comes to work space but with a Corner Cubby, I could just close the doors and no one would see the mess πŸ‘
                            To extend / improve the storage space the shelves could run on both back panels. This may make things overcrowded but when the screen doors are open it should okay.
                            Mike,
                            When I have all the bits and pieces figured out I will post the model with a full parts and fittings list. It would be nice also if I could have the prototype put together. Dermot's headsup on Hafele http://www.hafele.com/ie/ was just the source I needed, it has all the fittings I think I need and some that I was not aware of πŸ‘
                            The only fitting I need now is some kind of a spring loaded 'glider' / caster that would fix to the leading folding door. I think it probably would have to be spring loaded to cater for uneven floors. Maybe Hafele have something, will have to check fully.
                            • G Offline
                              GoldenFrog
                              Wow, Mike, that's a great idea! πŸ˜„
                              Remember, great minds think alike, and fools never differ.
                              • stefanqS Offline
                                stefanq
                                I think this is what you need. Be careful with the hinges (170 degree or so) for full opening. Still. I'm not sure if the doors will stay closed. Hafele used to have this product in my country. The product is wing line 170 from hettich (manufacturer)
                                • stefanqS Offline
                                  stefanq
                                  Sorry about my last post. I didn't payed attention about how the doors will work, my mistake. So, forget about my recommendation, I'm feeling kind of dumb right now. Apologies! 😳
                                    Mike Lucey
                                    No need for apologies Stefanq. I really appreciate your comments and suggestions.
                                    Mike
                                      Mike Lucey
                                      I've found a little time to progress the Corner Cubby a little further. It's just a PDF outlining the idea and including the optional L Shelves that were suggested.
                                      Corner Cubby Presentation.pdf
                                      • G Offline
                                        GoldenFrog
                                        I like it! Is this a real project? Is there space for you to sit in it when the door is closed?
                                          Mike Lucey
                                          No. The idea is to use the folding doors as a privscy screen while working.
                                          • X Offline
                                            xrok1
                                            corner chubby! with privacy screen! 🀣
                                            i'm sorry but i had to 😳 . everytime i saw this thread title it made me laugh.
                                            i hope it has internet connection. πŸ˜†
                                            β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                            • 1 / 3
