    Vray for sketchup
    renderpluginsextensions
    4 Posts 2 Posters 2.0k Views 2 Watching
    • D
      doy
      Hi! i am using Vray for sketchup.anybody encounter that the rendering engine is not showing up anymore?- Please help..Thanks
      • thomthomT
        Please state which version of VfSU you are using. The solution will often vary depending on this.
        Also, can you be more spesific? "not showing up"?
        Nothing happens when you click Render?
        You don't see the VfSU menus or toolbars in the UI?
        Note that the latest version 1.48.66 has a number of issues that ASGVis is working on fixing. If you experience problems with that version contact ASGVis at support@asgvis.com . It's also worth checking the ASGVis forums as well. (Note that the forums are not an official support channel - only the email is.)
        P.S. we have a V-Ray section here at SCF: http://forums.sketchucation.com/viewforum.php?f=322
        (I'll be moving this thread there.)
        • D
          doy
          Hi Thomthom, thanks. That's exactly what i'm trying to say. nothing happened when i click the render.It used to have after rendering the same view, same file. Then I tried re-naming the file, but unsuccessful, nothing happens. yes I'm using the latest version...Thanks again
          • thomthomT
            There are a number of causes for this. Most common appear to be materials.
            I'd advice you to check out the ASGVis forum where you will find a sticky that describes how to get hold of the error log. Then you can submit that error log and model to ASGVis support.
            Just in case you have come across a new issue.
