    Dxf export
    4 Posts 3 Posters 260 Views 3 Watching
    • P Offline
      pgw38
      Hello all,
      My name is Pierre, from sunny france (at least these last 5 minutes). I have a issue with the export to dxf. the dxf shows segments for arcs and not proper arcs. I tried to multiply the segments nb in sektchup but with some curves i do not have access to this feature. Is there any export option able to smooth the drawing or do I need to get back to sketchup and re-drawing the curves specifying 12_ segments or so for each of them ? It looks like a dummy question ? So I guess i am in the proper section of the forum. Thanks again for your help in there
        Exporting a 2D DXF will 'segment' the arcs/circles... BUT exporting a 3D DXF will give you 'proper' arcs/circles.
        I think that whatever the segmentation of an arc is in SUp will be ignored, and in the exported 2D DXF they'll all be set at 12 anyway... best to export it as 3D DXF.
        • P Offline
          pgw38
          Thanks a lot for the answer, I'll try that and let you know
          Pierre
          • Jean LemireJ Offline
            Jean Lemire
            Bonjour Pierre, hi folks.
            Tu peux t'inscrire au forum "Français" ici même sur SketchUcation.
            Tu n'a qu'à cliquer sur le bouton en haut à gauche de la fenêtre pour accéder à ton "User Control Panel".
            De là, tu peux t'inscrire aux autre forums qui t'intéressent (utilise l'onglet "User groups". Termine en cliquant sur le bouton "Submit" au bas de la page.
            Salutations et bienvenue sur SketchUcation.
