    Resuming Rendering from the Last Session ?? Any trick??
    renderpluginsextensions
    10 Posts 4 Posters 2.2k Views 4 Watching
    • A
      arjunmax09
      I'm using vrfsu version 1.05.3......Okay what is VrImage will somebody tell me?? And is there a facility in VRAY for su in any version that i can render a part of my view in 1 hr....save it and then render the remaining portion another day ........then save my session......then render the remaining part another day??? I mean just like Download Accelerator plus gives us the facility of broken downloading is there a facility for broken rendering that we are able to resume from the last session??
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • thomthomT
        No way to pause and resume.
        • A
          arjunmax09
          There's a power problem in India...i.e. there are frequent power breakdowns during summers...Some renders can take 8 to 10 hrs. Suppose if i start rendering a scene and go somewhere and return after 6 hrs. only to find that my pc has restarted since there was a power breakdown during the render.....I know that i should use a power backup .....but is there a facility in SketchUp or vray itself??
          • EarthMoverE
            EarthMover
            You can only pause animation renders in Vray and only between frames. No pausing capabilities for mid render stop and start. I believe, Kerkythea, Twilight, Maxwell, Thea & Fryrender all have pausing capabilities.
            Content Creator at Skapeup
            • thomthomT
              What you could do, to reduce the time when you need to re-render is to make V-Ray save your Lightcache and Irradiance maps. So if you need to restart, then you can use the IR and LC maps stored from the previous attempt - saving some processing time.
              • jenujacobJ
                jenujacob
                i am all too aware of this problem when i was back in india...
                i found the best way to overcome this was to use unbiased render engines like maxwell or even the new thea could work..
                u can save out a thea image and then render from the point it was saved again..
                • thomthomT
                  But does that help for situations where power is abruptly cut?
                  • jenujacobJ
                    jenujacob
                    i believe it will.. only if u remember to save out the thea image at regular intervals.. maybe this should be asked as a feature.. for incremental saving of the thea image... πŸ˜’
                    • A
                      arjunmax09
                      @jenujacob said:
                      thea image at regular intervals.. πŸ˜’
                      um....sorry to ask is "thea" a petname for Kerkythea or is it a name of renderer?? πŸ˜’
                      • jenujacobJ
                        jenujacob
                        its a new render engine from the makers of kerkythea...
                        Thea Home Page << Click Here
