    Preference Settings
    3 Posts 2 Posters 288 Views 2 Watching
      cdubea
      Hi there,
      I have a settings/preferences question.
      1. I have a custom default template with all my preferred fonts etc set.
      2. When working document with components, saving those components to a file results in the preferences being set for what I'm guessing is a default state.
      Is there a way to override this "default" state and have the saved components use the default template, or even better the settings of the parent document?
      I hope so because this is an amazing time consumer. I like to split out the individual components and then dimension them and such and then reimport them. Sometimes changes are necessary and doing a saveas results in having to reset the preferences.
      Help!
      thanks
        There's no [easy] way of changing the default settings...
        A fix would be this... open a new empty skp using the desired template.
        Import/load the just save_as'd component skp, inserting it at the origin [you'll want to explode it, then delete the original imported component in the browser too ?].
        Now save this new skp with the same name/path as the component thereby overwriting it with the copy that now has all of the font/dim styles etc you need...
          cdubea
          Ok. Thanks. I was afraid of that. Maybe I'll write a ruby to set them with one click.
