    Helpful Hint: cheat sheet watermark
    10 Posts 4 Posters 678 Views 4 Watching
    • kenK
      ken
      I work in steel, flat, round bar and etc. and I am always losing my cheat sheet for steel weights. Then suddenly it came to me. Make the cheat sheet a watermark. So now I turn on the watermark and have my info right there on the screen.
      Don't know if this will help anyone else, but for me, I will continue to add to the cheat sheet and know exactly where I put it.
      Ken
      • dermotcollD
        dermotcoll
        Sounds like a good idea to have it to hand like that but forgive me if I may sound silly Ken but how do you set it up? what program are you running it on etc?
        When you burn your arse - you gotta sit on the blisters!!
        • TIGT
          Use it as a Watermark [background or overlay] as part of a [new] Style...
          • kenK
            ken
            I enter the info into an Excel spreadsheet, print as a PDF. Open the PDF in Photoshop Elements, save as a PGN, and then use Sketchup watermark process in styles and presto, I have my info.
            Ken
            • dermotcollD
              dermotcoll
              Cheers Guys, I wasn't sure whether you meant whilst working in SU or not thus the confusion!!!
              • honoluludesktopH
                honoluludesktop
                Ken, Wow, that's a lot of plugins. You must hate it when your display gets messed up!
                Dermontcoll, Just guessing that you have never used SU's watermark before. Goto the menu bar and select: Window > Styles > Edit > Watermark (second icon from the right). Sorry if I am wrong.
                • dermotcollD
                  dermotcoll
                  You are right honolulu, but i dont see what I would need it for at the minute - can you give me some examples of when you use watermarks whilst modelling please and I may incorporate it into my workflow. Thanks.
                  • honoluludesktopH
                    honoluludesktop
                    I use watermarks as background images that I can place my model on, or if I want my logo included with a SU image. For a SU image, something like the below. Ken's use would have the number on top of the image.
                    http://forums.sketchucation.com/download/file.php?id=43129
                    • honoluludesktopH
                      honoluludesktop
                      Here is a SU interior with the watermark image in the window. Render below.
                      http://forums.idx-design.com/index.php?action=dlattach;topic=623.0;attach=2190;image
                      • dermotcollD
                        dermotcoll
                        Thanks for that. I could use that for setting a quick scene in a proposed interior design for my clients.
