    Issues in Grass material
    renderpluginsextensions
    3 Posts 2 Posters 907 Views 2 Watching
    • A
      arjunmax09
      Hello everyone i'm using Google SketchUp Pro 7.1 and vray version 1.05.30..... Below is an image of an architectural college model that i made in sketchup.....in the courtyards I applied grass... where it's coming as black ......
      Here, canteen view, in the sunken sitout area i applied grass where it's coming totally grey.....the grass was in sketchup material library and wasn't imported from any other external bitmap
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • thomthomT
        Not sure...
        In the render progress window - the one that pops up with all the text - if you look through the text, does it anywhere says something about that it fails to load a bitmap?
        Could you post a sample from the model with the texture?
        • A
          arjunmax09
          will surely upload my model......no i didn't check the messages .. the grass material was itself already in the sketchup material library.. it wasn't loaded from anywhere else... i mean any external jpeg images..has anyone experienced a problem where the alpha channels for transparency load into sketchup but don't show in the renders?? this file maybe got corrupt because the flowers showed up in render when i copy pasted them into a new untitled file
