    Blending in lazysteps !?
    5 Posts 3 Posters 337 Views 3 Watching
    • H Offline
      haynesc
      hi all
      how would i go about drawing in the lazy steps to join up the two arcs ?
      landscape.skp
        Take the top and bottom curves as welded rails [give them equal segments].
        Take the steps' rise+tread and weld into a curve.
        Now use EEbyRails and use the steps'-curve as the profile, the curves as the rails and the steps again as the melding profile...
        โ“
        • H Offline
          haynesc
          thanks worked perfectly !!
            Glad it did - I hadn't tried it - just thought it'd work.... ๐Ÿ˜ฎ
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              I did a test:
              1 - I selected only the two arcs.
              2 - I used the Sandbox Tool "From Contours".
              3 - I did some clean-up (less than 30 seconds).
              The result looks not too bad.
              Just ideas.
