    WIP - Garage fliptable
    16 Posts 9 Posters 1.4k Views 9 Watching
    • J
      Joarek
      Hello, thought i would post something i fiddled with the other day. It´s basically just a spacesaving table im planning on making for my garage.
      Any ideas to make it better appreciated 😄
      Renders made with Podium:
      Closed
      Open
      • R
        rdluther
        if you doubled the thickness of the tabletop you could recess the legs in the top and make a smooth outter surface. Just a thought.
        • J
          Joarek
          Hmm, not a bad idea. Though the table would be rather heavy i think.
          But you gave me something to think about, cheers 😍
          • TIGT
            OR you could make the legs as the end edges of the top, so it's then all flush when upright, without increasing the 'recess' depth ?
            Also where is the space ;gained; in the wall depth ? A ~6"+ recess projects into the house/external wall ??
            • J
              Joarek
              Hmm, pherhaps. I would have to come up with some solution on a hinge that could tolerate the weight/abuse the table needs to withstand.
              Unfortunately i do not have a garage to put this thing in yet, so it´s more of a plan when i get one 😳 But the depth into the wall is 150mm + 35 for the table itself. Just enough room to stuff some tools in there.
              • dermotcollD
                dermotcoll
                I think you are losing too much space by building a recessed cavity to hold your tools. The space used by the tool recess is a small percentage of the overall wall. Would it not be better to have a full pegboard wall capable of storing more tools and incorporate the bench into that space? Just a thought. Nice visual by the way on the last one.
                When you burn your arse - you gotta sit on the blisters!!
                • soloS
                  solo
                  I think it needs to be lockable for it to have a real function, as the rest of the walls are empty so it's not a space issue, but securing your tools may be a good reason for such a storage idea.
                  http://www.solos-art.com
                  • M
                    MtnArch
                    I think the depth of the tabletop will make it tough to grab the tools, too - especially the ones up high!
                    Highest Regards,
                    Alan T. Hendry, RA
                    Architect
                    • mitcorbM
                      mitcorb
                      Maybe some type of continuous piano hinge? But don't count on drywall for support. You will need some solid lumber for the hinge.
                      • J
                        Joarek
                        Yes, thats one of the reasons. The thought was to have a bolt go through on the top and then drill a hole in it so a padlock can be used to secure it all. And space will likely be an issue, i just made the room that big for ease sakes i guess.
                        I messured it roughly and it seemed to work ok. The main thing for me is tablespace that will hold large(ish) parts and tools 😄
                        Yes, i looked for something like that in some catalogs i have but found only "puny" kinds that seemed to be too weak.
                        Also, it would be skrewed into a ridgid "skeleton".
                        !["skeleton"](/uploads/imported_attachments/Mkfk_4.jpg ""skeleton"")
                        Thanks for all the comments so far guys and sorry for my poor english 😄
                        Edit:
                        You may be right, though this idea is without knowing anything of the given garagemeasurements and pretending the wall would accommodate this "setup" hehe.
                        I will ofc have pegboards aswell as i have loads and loads of tools. But this would be storage for the more expensive tools perhaps with a padlock.
                        • chrisglasierC
                          chrisglasier
                          You need some power points ?
                          With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                          • J
                            Joarek
                            Hmm?
                            Not sure what you mean exactly.
                            • chrisglasierC
                              chrisglasier
                              • J
                                Joarek
                                Oh yes, sure need that. But im focusing on the fliptable itself here 💚
                                • olisheaO
                                  olishea
                                  mate why do you keep posting mac screenshots? why not just the image? good stuff
                                  oli
                                  • J
                                    Joarek
                                    I guess i just like the HUD border 😄
                                    If it annoys you let me know 😆
