    Png and Output Issues
    renderpluginsextensions
    4 Posts 3 Posters 817 Views 3 Watching
    • A
      arjunmax09
      I'm using Vray for SketchUp version 1.05.30.... Recently I rendered a scene having flowers png bitmap faceme component... unfortunately ....it comes as black in vray render output
      paintoriginal.JPGThe original image
      arjun2.jpgThe rendered output
      Also I'd like to ask.. how to get exactly the same sketchup scene in vray output.. In the above images you can see that there is some difference in zoom..and is there a way to remove that bluish default sky background and add one of my own inside vray... no any photoshopping or post processing...
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • EarthMoverE
        EarthMover
        That's odd. Is your clipmap inverted? The rose shrub you are using is one that I made personally and I've use it on multiple projects rendered with Vray and never had a problem. I've tested it with the latest build of Vray and it renders fine. Perhaps you should try upgrading. With the new version you don't need a clipmap for faceme plants. It's a free upgrade and well worth it, IMO.
        Regarding getting the render output to match the SU camera, you have to use ThomThom's Vray Toys plugin to set the aspect ratio in SU to match that of Vray.
        Content Creator at Skapeup
        • thomthomT
          Material often render like that if you imported a V-Ray material and didn't re-link the textures.
          • A
            arjunmax09
            I have full version of Vray version 1.05.30 ... will I be able to upgrade it for free??
            Can you upload a screenshot of the above procedure..?? I've tried doin' it but the vray output remains the same... even in the options tab...
