Forcing alignment to plane
Simple Newbie question:
I have drawn some geometry and it is slightly skewed to the plane I drew it in (not sure what I did...)
If I want to force something to a plane, what command do I use and how do I do it?
Thanks!
Mark
There are scripts to 'flatten' geometry - if that's too draconian try using the Sandbox tools to Drape the edges down onto the surface a a large rectangle you've drawn below it so again then are coplanar...
A little more detail about this mess-up might help us tailor a better response ?
Register LoginAdvertisement
