Thea Render is about to be launched..(edit available now)
Does Thea only run on SU Pro? I only have SU free here in the office and can not get anything to run.
Like you I also only have SU 7 free and Thea as well as the SU2TH plugin works fine for me, Scott...
Got it working now....One word....WOW!!!!
Scott
I think it is unfair. Do you have latest LightUp version installed?
Please notify me if you experience problems with LightUp while having WxSU 0.3 installed. This message must be annoying to you. Does it show up every SU start?I also hope Adam will test the SU-2-Thea plugin and revise his opinion or help me to resolve any potential problems.
This is about WxSU not playing well with SketchUp. Its not about SU-2-Thea per se - though I appreciate if you've built on WxSU, you'll run into this.
The problem is WxSU does some truly heinous hacks of Ruby to work under SketchUp. Specifically, it tries to hide the problem by lowering the priority of the thread in an attempt to make sure it doesn't run.. Firstly this is a shit solution. Secondly, as soon as somebody sleeps, the thread will be scheduled and if you've not got a WxSU window open, it just breaks.
I tried to get the author of WxSU to address the issue but didn't anywhere and got tired of endless support of LightUp regarding this issue.
Thanks Adam for the explanation. I am in contact with Peter and hope to have the 'sleep' issue resolved soon.
@Gaieus thx for the precisions !
Hi Tomasz
I have SU 7.1 free and SU 6 pro installed but SU2TH only shows SU 6 as an install option.
Good news is that SU2TH is very quick.Thanks
Dave
@dtrarch said:
SU2TH only shows SU 6 as an install option.??
Hmm. It checks "HKLM\SOFTWARE\Google\Google SketchUp 7\InstallLocation", maybe you have installed SU just for a single user.. Quick solution - install it to C:\TempSU2TH and move all files to SU7\Plugins folder.
Well good luck..
I just downloaded your installer to check the WxSU version and ensure I'm not just becoming grumpy in my old age, and indeed WxSU still has this special code in "App.rb":
# This is the main entry point to the WxSU;;App object. This method performs some thread kludges # so that wxRuby and SketchUp play well together. # After creating an App object with 'new', call 'start' to initiate wxRuby. # For example; # WxSU;;App.new.start def start if (not is_main_loop_running) @thread = Thread.new { main_loop } @thread.priority = -1 # Kludge to lower the priority of wx; seems to work really well end return(self) endNow wash your hands.
I had problems previously with WxSU when Chris Fulmer used it for one of his color plugins and I had to delete it.
It seems now the same problems for me with the SU2TH exporter. Once I use the exporter and call the WxSU plugin, I am able to export to Thea just fine, but to try and go back and continue working in the SU window, I am having SU freeze up. I tried it with three different scenarios, including a simple scene export with just a box. To go back and work in SU after exporting causes SU to lock up. It's the exact same thing that was happening after running Chris's plugin and for me. It was always traced back to the WxSU tie in.
Thomasz
Will give it a try
Dave
Yep. It is an issue that is present in SU7. Surprisingly It doesn't appear in SU6. I believe it is related to how SU deals with separate threads. I need to look at it much closer.
Its really sad! but a fact of life I suppose, that all these plugins sooner or later cause problems. Even my Windows Tools ruby which I wrote last year, now has problems running under SU 7. And it was not till I uninstalled Vray 01.05.30 that all my exiting SU problems went away.
Its almost enough to make me watch Idol or Survivor.....but not quite
Thomasz
Install for V7 worked as you suggested and thanks again.
Quick eval for Thea.
Very technical and full featured.
Not for the point and shoot user that wants a quick and easy output.
Kt as it stands actually seems easier to get to solution for Photon mapped output.
No object animation either.Hmmm?
Dave
@pixero said:
@pixero said:
Anyone but me who gets a wxSU warning/error upon SU launch?
It warns about possible problems with other plugins like LightUp.Can you post exact message, please?
SU-2-Thea uses WxSU 0.3 version in which interaction issues with other software has been resolved.Here it is.
Maybe it's LightUp's own wxSU warning?You can disable LightUp warnings like this by opening the Ruby Console and typing:
Sketchup.write_default("LightUp", "Warnings", false)But be aware that currently WxSU does have fundamental problems working with other plugins.
Not for the point and shoot user that wants a quick and easy output.Unbiased methods give excellent results without touching any settings. TR1 is especially efficient with exterior shots. Biassed method requires serious knowledge, but once set-up correctly is way faster then unbiased.
The exporter is still in beta stage and lacks animation and environment settings. During open beta all bugs should be ironed out and missing features added.
how is the speed?
is as fast thea as vray?
does someone know that?
I use Maxwell, is not as fast as vray but a perfect quality.
just try it - there are more things to consider than the speed. Price, platforms, plugins, interface, possibilities and variations. If You use Thea You can easily use Kerkythea or Twilight. You can use it with SketchUP or with other plugins or with any application that can export 3ds or obj. You can use it on PC, MAC or Linux. You have biased and unbiased render in one package. Price as of now - โฌ161.16 Thea Render application license + 2 node licenses.
Give me a better offer? -
Thomasz
Problem with SU 7.1 here too.
Lockup on run and had to re-install the plugin again as well.
Could use some "Camera" pre-sets as used in Thea as there seems to be over exposure in the default Thea render settings.
f stop shutter speed iso etc.Truth is that KT, Twilight are plenty good enough for most presentation work.
Thea is of course the next step up for close in and interior killer PReal for those who need that level of output.
Sort of KT on steroids.Pricing is fair but not compelling.
Dave
@reymond said:
how is the speed?
Be mindful it ain't anywhere as easy to get a grip with!!
Que...???
Would you mind elaborating a bit more on this, Richard...?
From what I've seen on the Thea Forum, users find the UI (in particular the Material Editor) really easy and intuitive...
With your input, this post could be even better ๐
Register LoginAdvertisement
