    Thea Render is about to be launched..(edit available now)
    extensions
    86 Posts 26 Posters 22.3k Views 26 Watching
    • PixeroP Offline
      Pixero
      I think it is unfair. Do you have latest LightUp version installed?
      Please notify me if you experience problems with LightUp while having WxSU 0.3 installed. This message must be annoying to you. Does it show up every SU start?
      I also hope Adam will test the SU-2-Thea plugin and revise his opinion or help me to resolve any potential problems.
      I have v1.8a and yes it shows up every time I start SU. I'll let you know if there is any problems with LightUp.
      Maybe you should contact Adam to solve this.
        tomasz
        Thank you for the info. I have already contacted Adam. I believe we will resolve it quickly.
          ScottPara
          Does Thea only run on SU Pro? I only have SU free here in the office and can not get anything to run.
          Scott
          Love the fact that some HATE my avatar.....
            tomasz
            It runs just fine on both versions Pro & Free (6 & 7). I think your SU is not returning proper path when Sketchup.find_support_file "plugins" is typed in the Ruby console. If it is the case please send me a PM.
            • FrederikF Offline
              Frederik
              Like you I also only have SU 7 free and Thea as well as the SU2TH plugin works fine for me, Scott...
              Cheers
              Kim Frederik
                ScottPara
                Got it working now....One word....WOW!!!!
                Scott
                • AdamBA Offline
                  AdamB
                  This is about WxSU not playing well with SketchUp. Its not about SU-2-Thea per se - though I appreciate if you've built on WxSU, you'll run into this.
                  The problem is WxSU does some truly heinous hacks of Ruby to work under SketchUp. Specifically, it tries to hide the problem by lowering the priority of the thread in an attempt to make sure it doesn't run.. Firstly this is a shit solution. Secondly, as soon as somebody sleeps, the thread will be scheduled and if you've not got a WxSU window open, it just breaks.
                  I tried to get the author of WxSU to address the issue but didn't anywhere and got tired of endless support of LightUp regarding this issue.
                    tomasz
                    Thanks Adam for the explanation. I am in contact with Peter and hope to have the 'sleep' issue resolved soon.
                      @Gaieus thx for the precisions !
                        dtrarch
                        Hi Tomasz
                        I have SU 7.1 free and SU 6 pro installed but SU2TH only shows SU 6 as an install option.
                        ?? ๐Ÿ˜ฎ
                        Good news is that SU2TH is very quick.
                        Dave
                          tomasz
                          @dtrarch said:
                          SU2TH only shows SU 6 as an install option.?? ๐Ÿ˜ฎ
                          Hmm. It checks "HKLM\SOFTWARE\Google\Google SketchUp 7\InstallLocation", maybe you have installed SU just for a single user.. Quick solution - install it to C:\TempSU2TH and move all files to SU7\Plugins folder.
                          • AdamBA Offline
                            AdamB
                            Well good luck..
                            I just downloaded your installer to check the WxSU version and ensure I'm not just becoming grumpy in my old age, and indeed WxSU still has this special code in "App.rb":
                                # This is the main entry point to the WxSU;;App object.  This method performs some thread kludges
                                # so that wxRuby and SketchUp play well together.
                                # After creating an App object with 'new', call 'start' to initiate wxRuby.
                                # For example;
                                #   WxSU;;App.new.start
                                def start
                                  if (not is_main_loop_running)
                                    @thread = Thread.new { main_loop }
                                    @thread.priority = -1  # Kludge to lower the priority of wx; seems to work really well
                                  return(self)
                            Now wash your hands.
                            • EarthMoverE Offline
                              EarthMover
                              I had problems previously with WxSU when Chris Fulmer used it for one of his color plugins and I had to delete it.
                              It seems now the same problems for me with the SU2TH exporter. Once I use the exporter and call the WxSU plugin, I am able to export to Thea just fine, but to try and go back and continue working in the SU window, I am having SU freeze up. I tried it with three different scenarios, including a simple scene export with just a box. To go back and work in SU after exporting causes SU to lock up. It's the exact same thing that was happening after running Chris's plugin and for me. It was always traced back to the WxSU tie in.
                              Content Creator at Skapeup
                                dtrarch
                                Thomasz
                                Will give it a try
                                Dave
                                  tomasz
                                  Yep. It is an issue that is present in SU7. Surprisingly It doesn't appear in SU6. I believe it is related to how SU deals with separate threads. I need to look at it much closer.
                                    tomot
                                    Its really sad! but a fact of life I suppose, that all these plugins sooner or later cause problems. Even my Windows Tools ruby which I wrote last year, now has problems running under SU 7. And it was not till I uninstalled Vray 01.05.30 that all my exiting SU problems went away.
                                    http://forums.sketchucation.com/viewtopic.php?f=11&t=26342
                                    Its almost enough to make me watch Idol or Survivor.....but not quite ๐Ÿ˜„
                                    my plugins
                                    tomot
                                      dtrarch
                                      Thomasz
                                      Install for V7 worked as you suggested and thanks again.
                                      Quick eval for Thea.
                                      Very technical and full featured.
                                      Not for the point and shoot user that wants a quick and easy output.
                                      Kt as it stands actually seems easier to get to solution for Photon mapped output.
                                      No object animation either.
                                      Hmmm?
                                      Dave
                                      • AdamBA Offline
                                        AdamB
                                        @pixero said:
                                        @pixero said:
                                        Anyone but me who gets a wxSU warning/error upon SU launch?
                                        It warns about possible problems with other plugins like LightUp.
                                        Can you post exact message, please?
                                        SU-2-Thea uses WxSU 0.3 version in which interaction issues with other software has been resolved.
                                        Here it is.
                                        Maybe it's LightUp's own wxSU warning?
                                        You can disable LightUp warnings like this by opening the Ruby Console and typing:
                                        Sketchup.write_default("LightUp", "Warnings", false)
                                        But be aware that currently WxSU does have fundamental problems working with other plugins.
                                          tomasz
                                          Unbiased methods give excellent results without touching any settings. TR1 is especially efficient with exterior shots. Biassed method requires serious knowledge, but once set-up correctly is way faster then unbiased.
                                          The exporter is still in beta stage and lacks animation and environment settings. During open beta all bugs should be ironed out and missing features added.
                                            reymond
                                            how is the speed? โ“
                                            is as fast thea as vray? โ“
                                            does someone know that? ๐Ÿ’ญ
                                            I use Maxwell, is not as fast as vray but a perfect quality.
                                            Sketchup & Vray Trainer
                                            • 2 / 5
