    Where are the Auto-save files?
    7 Posts 3 Posters 550 Views 3 Watching
    • ken28875K Offline
      ken28875
      Hello everyone,
      Out of curiosity, would anyone know where the Auto-saves files are located?
      I know that an auto-save file will be in the same folder than the original Skp file, but it does not stay there.
      For example, if I set my Auto-save every 10 minutes, I will find one auto-saved file in the folder but it will disappear like a few minutes later.
      How can I find the auto-saved file that was saved like 7 minutes ago for example (or 20 minutes, or 30 minutes ago, etc.).
      Thanks!
      _KN
      Follow Your Dreams.
      • Mike LuceyM Offline
        Mike Lucey
        Hi ken,
        This link should explain all,
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36212
        Mike
        • ken28875K Offline
          ken28875
          @mike lucey said:
          Hi ken,
          Mike
          Thanks, Mike!
          Have a nice day, β˜€
          _KN
          Follow Your Dreams.
            There's only one AutoSaved file and that is between 0 and NN minutes old depending on the time period you set and when SUp crashes - a normal exit removes the file - then only the SKB file is the last saved version.
            I made a tool 'Archiver' that lets you make 'snapshot' archived copies of the model as you go - you'd shortcut key it [off the File menu] and manually save your model at critical stages - if you crash or want to revert to an earlier idea then the archived versions are 'date/time-stamped' and stored in the Archives folder with the model...
            • ken28875K Offline
              ken28875
              Great! Where can I download that Archiver tool?
              Thanks, TIG.
              _KN
              Follow Your Dreams.
                Didier's Ruby Library Depot site at crai has loads of scripts http://www.crai.archi.fr/RubylibraryDepot/Ruby/em_fil_page.htm
                Archiver is on this page...
                However you'd probably be quicker getting it here http://forums.sketchucation.com/viewtopic.php?p=149749#p149749
                Use the built-in Search tool - it'll return a load of interesting stuff...
                • ken28875K Offline
                  ken28875
                  Thank you, Sir. πŸ‘
                  Follow Your Dreams.
