    ANOTHER "How-To" Question (Sorry!)
    10 Posts 8 Posters 530 Views 8 Watching
    • leedeeteeL Offline
      leedeetee
      Hi (again!)
      Just wondering what the best way would be to create a 'scramble net'?
      When importing our symbols via .3ds into SU the files are huuuuge, the one attached is almost 7MB! ๐Ÿ˜ฎ I've figured that it's the nets which are causing 6.5MB in file size in this particlular example so I am just wondering if anyone can suggest the best way to create nets like in the example below? I'd guess using a circle on the end of an arc, and use follow me? Am i anywhere near the mark?
      Thanks again.
        dedmin
        Make the grid on the xy plane and then use Fredo's taper and radial bend tools
          d12dozr
          ...or you could just use a texture projected onto a curved surface if your camera isn't going to be too close to the net. This will keep the file size to a minimum.
          http://goo.gl/f7ooYh
          • daleD Offline
            dale
            Another method using follow me. Create your arc "path". Make a circle at the base of the path. Select (highlight) your path, select the follow me tool, and click on the circle. You can copy, paste, rotate, this original to make your components. Follow the same for the horizontals
            • david_hD Offline
              david_h
              I tried it just for fun. I am sure there a million ways to do this. Each of these took just a minute or 2.
              the first one was done with Fredo Stretch Scale tool and Lattic-izer. Not so hot since square rope is hard to come by. Which reminds me that Lattice-zer would be great if you could opt for the number of faces of your extrusion. Max does that.
              The second one is Extrude loft by edges things with Lines2tubes.rb afteward. Just a thought.
                Try ExtrudeEdgesByRailsByFace with a small modestly segmented circle as a face to extrude.
                You need to draw the outer curves and also curves for the ''ends - the number of segments in these dictates the number of 'ribs' in the final 'lattice'... โ˜€
                  leedeetee
                  Thanks so much for all the brilliant input, I really appreciate it, will give them all a whirl tomorrow at work.
                  Cheers. ๐Ÿ‘
                  • Jean LemireJ Offline
                    Jean Lemire
                    Hi folks.
                    Without any plugin, just to learn the basic capabilities of SU.
                    Curved net.skp
                      leedeetee
                      Thanks so much for takign the time to reply, Jean. I very much appreciate it. ๐Ÿ‘
                        Unless you really need the geometry for whatever reason, I would also go along with a nice texture.
