    Finding area and linear lengths
    7 Posts 4 Posters 567 Views 4 Watching
      Larryo
      All,
      Re: Sketch 7.1
      Is there a way to find the area of a surface?
      And is there a way to find the linear dimension of a line, or several lines?
      Above use to determine sq footage for walls, floor, etc., and lineal feet for trim, moulding to cost out project.
      Thx
      Larry
      Sketch 7.1 Mac
      Larryo
      • massimoM Offline
        massimo Moderator
        Hi Larry, select your line (or lines) or your surface (or surfaces) then right click-->entity info.
          dedmin
          You can have the surface area of all the faces with the same material - just select a surface and right click - Area
          You can compute the estimate too
          • massimoM Offline
            massimo Moderator
            Dedmin, I think that the "cost" tool comes with a plugin, no?
              dedmin
              • massimoM Offline
                massimo Moderator
                Ok, thanks, didn't know about that. I have that extension disabled. πŸ˜„
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi Larry, hi folks.
                  In supplement, the Text Tool will default to these informations:
                  • line: length.
                  • face: area.
                  • endpoint: coordinates in the form X,Y,Z.
                  One trick: you can switch units between use. For example, if you use the Text Tool on a face, you will get the area in square feet. Then, switch to meters and you can add another text entity with the surface in square meters.
                  Just ideas.
