    Which plugin can make this?
    10 Posts 7 Posters 1.8k Views 7 Watching
    • H Offline
      hebelup
      Hi i want to do this easy way. when i want to do this take much time and very hard.
      Which plugin can make this thanks?
      (Sorry for bad english:)
      http://www.emresezer.com/3boyut/1ornekcopy.jpg
      • soloS Offline
        solo
        Sketchup vanila.
        http://www.solos-art.com
          Make what exactly ?
          • H Offline
            hebelup
            @tig said:
            Make what exactly ?
            picture updated thanks.
            • K Offline
              KXI System
              I think Greble, the other guys will fill you in on that.
              Getting the perfect sig is hard...
              Google it!
              • utilerU Offline
                utiler
                I think if you contact GOH [1001bit author] he may be able to add this to the future releases...
                Just Curious...
                  There's a similar thread about making 'grooves' - I illustrated how to do it with my Lattice-izer tool... You draw the pattern [any] over a face in a group and then lattice-ize it, at the required +ve width & -ve depth and the wall faces pop forward leaving the grooves in place...Untitled.png
                  • bagateloB Offline
                    bagatelo
                    Protude and Windowizer can do that.
                    Try to set negative values in fields for extrude
                    in windowizer.
                    http://www.smustard.com/script/Windowizer3
                    http://sketchuptips.blogspot.com/2007/10/plugin-protrude.html
                    • G Offline
                      gavvy
                      i have wrote the plugin (Change from the lattice)
                      but i don\t know how to upload my plugin 😳
                      • G Offline
                        gavvy
                        is it like this??
