    "Hide Rest of Model" component Edit Wish
    16 Posts 7 Posters 1.7k Views 7 Watching
    • david_hD Offline
      david_h
      I know I have asked this before. It doesn't seem to get a lot of traction for discussion and maybe I am missing something but I have always wished that when one wishes to edit Nested Groups and components that one could have the option of not only hiding the rest of the model but keeping the rest of the nested component or group visible or at least the next item up the tree.
      FOr example. . if I have a complicated window Group that would have a tree looking like this. . .
      Window Group
      Window Frame (component)
      Mullion (Component)
      glazing etc etc.
      I could work on the Glazing and still keep the mullions and Frames visible but have the rest of the model hidden. Other ways it oculd work is with stairs Risers, treads, Landings railings. .. all nested components of eachother. Work on those items while keeping their relatives open but the full context model hidden.
      Can that be done???? Ruby? Outliner? Help.
      p.s. It can be kinda done with layer management but there's got to be a more elegant way. IT would seem to me that in OUTLINER one could click a button called Visible/Invisible or something like that.
      Thx,
      David_H
      • G Offline
        GoldenFrog
        Hm...seems like a great idea, but why not just hide the model, all but the component you want to edit? πŸ˜„
        Remember, great minds think alike, and fools never differ.
        • X Offline
          xrok1
          maybe this is what layers are for? πŸ˜‰
          you could make a layer and call it 'editing', then when you select your window group, in entity info change it to the 'editing' layer and hide the other layers. when you're done your edit reverse the steps.
          i'm sure this could easily be automated with a ruby to but...
          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          • david_hD Offline
            david_h
            Okay. . smartie pantses. . .I do use layers and I do use Hide rest of model, but it's an all or nothing thing and layers require going back and forth thru the layer menu and such. IT would just seem to me to be more "convenient" if you will to have visibility of nested objects appear or disappear up or down the tree. do ya'Falla? πŸ’š
              I do, David, I do...
              The hide rest of model function is very handy but it's an "all or nothing" solution at the time and often you need someof the context but not all the model. That is it, truly.
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                You can use a scene to memorise the layers on/off properties.
                Then, it is only one click on a scene tab to set the layers in one go instead of going in the layer menu and clicking a lot of them.
                Just ideas.
                  Yes, Jean but you cannot set up scenes for every possible modelling scenario! I use those scenes and often combine them with hide rest of model and layer visibility but you cannot spend more time by setting up a whole bunch of scenes than modelling itself!
                  • david_hD Offline
                    david_h
                    That is it, truly.
                    Well fix it Dang it!!! πŸ˜„
                    No seriously. . .even though everyone has a work flow that either works or not works with the situation as it is, For ME i would think a ruby to do this would be awesome, but alas and Alack. . .I am not skilled in the writing and testing of ruby code . . .stuff. So if any of the Ruby code Magi could take a look at this I think it would be very useful. 😳
                      Well, it seems there is nothing to "fix" as it is not a bug but there would be nice to have a feature like that.
                      • X Offline
                        xrok1
                        how about this: make a keyboard shortcut for invert selection, hide and, unhide last. now select your parent group, hit your invert selected shortcut then your hide short cut, do your edit then hit your unhide all shortcut. πŸ˜‰ if you have some hidden not hidden you want to remember you could create a page first then use that to restore temporary hidden things instead of using unhide last.
                        • david_hD Offline
                          david_h
                          Hmmm. That's not bad. I have the shortcuts already. I will try that.
                          Thanks. . . .
                          BUT SOMEONE STLL THINK ABOUT THE RUBY!!!! πŸ’š
                          Well that is what I meant. . ..golly! πŸ˜‰
                          • jgbJ Offline
                            jgb
                            Sounds like a good idea to me, as I run into this a lot, and I use extensive layering and nested groups/comps. I keep hiding/unhiding ("H" key shortcut} but like said, I need to see some parts, even if shaded, visible as reference during my drawing operations.
                            David, you need to put this thread or the initial idea on the "suggestions" thread.
                            My only concern is how would you control the visibility?
                            jgb
                            • david_hD Offline
                              david_h
                              I didn't really know where the best place to post this. .. so if it is in the wrong place, mea culpa. . .
                              As far as visibility options go in this "fantasy ruby" that I am imagining. . ..I would think that when you are in a complex nested window component, for instance you could right click on it and a flag would say, "Show Parent" or "Hide Parent" or toggle by keystroke . .. I dunno. . . just spit-ballin' here.
                              Oh I do hope some ruby Guru gives this a shot. . . oh I do! I do! I do! I do! I do! I do! I do!:mrgreen:
                              • X Offline
                                xrok1
                                i think the best place for this function would be to add it to thomthom selection toys maybe you could suggest it in that thread, but i do get the impression thom is busy with something amazing right now! πŸ’š
                                  Charlie__V
                                  For example. . if I have a complicated window Group that would have a tree looking like this. . .
                                  Try my quick/dirty method:
                                  Window Group
                                  _____Window Frame...cntrl + C the window frame component
                                  __________Mullion (Component)
                                  _______________Glazing etc etc. ...cntrl + V the window frame component
                                  I could work on the Glazing and still keep the mullions and Frames visible but have the rest of the model hidden. Work with the copied comp(s). within your active comp. & delete when complete.
                                  Thx,
                                  David_H
                                  David,
                                  Above is convoluted at best....though I like the prospect of next of kin visibility ;~)
                                  Best,
                                  Charlie
                                  • david_hD Offline
                                    david_h
                                    I am not sure I follow that methodology, but that shouldn't surprise anyone! πŸ’š I just need to give it a try tho. IT's probably pretty good.
