    Texture position
    renderpluginsextensions
    10 Posts 2 Posters 929 Views 2 Watching
      Tarsuar
      Hi everyone!
      I've been reading the forum for some days and was very useful for learning SU tricks.
      But now I need some help from you guys.
      I've got this 2 textures, see the Screenshot:
      http://www.tarsuar.es/su01.jpg
      I tried to move the texture 2 to this position:
      http://www.tarsuar.es/su02.jpg
      But when rendering whit Vray is still on the start position. No matter where you place the texture 2, it's always rendered on the same place with Vray (can't fit them). See it here:
      http://www.tarsuar.es/su03.jpg
      Both textures are Vray Linked Materials with a reflection layer.
      How can I move the textures to the place I want to and render them with Vray?
      Thanks in advance!
        1. What version of VfSU do you use? You say you have a Linked material - are you using the original version? There has been 3 versions after that - one just released. They all behave differently in certain areas - please state exactly which version you are using.
        2. Your two first images are they same ones. I can't tell what you are trying to do.
          Tarsuar
          Ok, fixed second picture.
          Vray version is 1.0
            I see.
            Maybe it's a bug in that version... I've not used it for years - so I don't remember. If that face nested in groups? What if you convert them to components?
              Tarsuar
              There are no groups on the scene.
              I tryed to convert the texture 2 zone into a cmponent, but it disappears when rendered, it's like nothing is there.
                There was a bug in the older versions where objects would not render. Some times it would help to reopen the scene.
                  Tarsuar
                  Maybe it's time to update my version.
                  Well... if anyone got this same problem post your answer please πŸ˜„
                  I'm working with this version for about 1 year on my company and always had to skip this kind of things
                    There was a version just released - but I would recommend you hold your upgrade until a patch has been released.
                    Meanwhile - can you share the model or parts of it? For investigation?
                      Tarsuar
                      Sure
                      You can download the file here:
                      http://www.tarsuar.es/h_clean.skp
                      I copy/pasted on a empty file, vray materials maybe are missed on the material editor
                        I don't see why it would render correct for you. It render fine with the latest version. (I don't have the original to try any more)
