    Matrix Multiplication Explained
    10 Posts 5 Posters 971 Views 5 Watching
      MartinRinehart
      I've written another appendix for the tutorial. It explains matrix multiplication. Hopefully, this explanation is a lot clearer than most of what you find if you search the web for this topic. It answers that burning question:
      Why isn't matrix multiplication commutative?
      I've also made some improvements to the "how does the transformation matrix work" appendix.
      This board doesn't permit .html files as attachments. Change the .txt extension back to .html and open either in your favorite browser.
      Matrix Multiplication - change .txt to .html
      Transformation Matrix - change .txt to .html
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        remus
        Nice explanation, bit programming orientated in my opinion but shouldnt cause any problems given the target audience. If i was being pedantic, id also say it doesnt really explain why matrix multiplication is non-commutative, rather it demonstrates that it is non-commutative (probably a good thing though, as id guess the answer is largely irrelevant to the typical sketchup scripter and would add a great deal of complexity.)
        • honoluludesktopH Offline
          honoluludesktop
          Saved your post for a later day:-) Thanks.
            MartinRinehart
            @remus said:
            as id guess the answer [why not commutative?] is largely irrelevant to the typical sketchup scripter and would add a great deal of complexity.)
            I'd guess that the non-commutative part bites everyone who codes with transformations. Let's see, is that rotation * scale or ... It's got me more than once.
              "non-commutative" ❓
                remus
                Sorry, poor wording on my part. I meant why matrix multiplication is non-commutative probably isnt important to most scripters, whereas the fact that it is non-commutative is clearly very important.
                Thom, commutativity is the property that "order doesnt matter", for example 23 = 32 and 4+5 = 5+4, but if youve got 2 matrices A and B, AB != BA. Multiplication and addition are said to be commutative and matrix multiplication is said to be non-commutative.
                  Ah yea - I've been puzzled by that. Why a scale * rotate isn't the same as rotate * scale.
                    But that is the same as doing it manually ?
                      MartinRinehart
                      What that is "that"?
                        That 'that' is manually rotating about a point and then scaling in a certain axis often gives quite different results from scaling in a certain axis then rotating about the same point πŸ˜•
                        That is that ! πŸ˜‰
