    [REQ] FBX Import
    14 Posts 6 Posters 3.0k Views 6 Watching
    • PixeroP Offline
      Pixero
      I know it's been asked before but a working FBX import would really make life easier.
      I would pay for having this. Please! 😄
        I wish for one too.
        Though making a ruby plugin it for it would not be easy:
        http://en.wikipedia.org/wiki/FBX
        The FBX file format is proprietary and is not documented. Autodesk provides a C++ FBX SDK that can read, write, and convert to/from FBX files.
          I think that this http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=7851697
          will convert fbx to other file formats that can then be imported into Sketchup, and vice versa ?
            Is that the latest one? It says 6...
            The latest seem to be 2010.2 - http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=10775855
              You are right - my link is out of date - yours is the most recent version... 👍
                chrisjk
                If you have a Mac available and not too much money then Cheetah 3D will import FBX and export in formats that SU can use.Likewse Rhino can do this - certainly in the Windows version but on my Mac the function seems to crash the program (it's only in Beta for the Mac). The Evaluation version of Rhino will let you save 25 times before demanding money..
                Chris
                  Rhino exports .skp files? When did they start doing that?
                    chrisjk
                    I meant that Rhino could import FBX and export something that SU could use rather than a native SU file - ditto Cheetah thus using these programs as intermediaries only.
                    Chris
                      troyhome
                      This would be nice- i know you can convert with FBX conversion program, but to natively support this format would be useful.
                      IOviz.com
                      SU Pro 2024 PC
                      • X Offline
                        xrok1
                        would be nice for sending baked textures into SU using lightup. does anyone know why adam choose this format for lightup anyway. would have been nicer to have something that could be imported for baking??? 😕
                        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • PixeroP Offline
                          Pixero
                          I know that there are workarounds that kind of works, but workflow wise they are a nightmare.
                          Now when 3dsMax can open skp files natively without problem a fbx importer plugin/script that actually works with textures and all would open up many possibilities. Importing Revit files as dwgs doesnt work great so fbx would be the best format for that also.
                          Last week I sat with some Autodesk people that told me that they have more developers just for fbx than any competing software has for their entire software.
                          If any developer reads this I strongly believe a fbx importer for SU would sell commercially, so go for it!
                          • PixeroP Offline
                            Pixero
                            FBX works great with for example Unity real time engine.
                              I often use 3DSMax to generate terrains - then export for SU. But both DWG and 3DS limits the max number of faces in one object to 32K. So I have to split it up. FBX don't have this limitation, does it?
                              • X Offline
                                xrok1
                                yes, it works great with walkabout3D too. maybe adam could provide an fbx importer as part of lightup since he exports to it and obviously has a handle on the format. ☀
