    Sketchup doesnt work in win7?
    8 Posts 5 Posters 905 Views 5 Watching
    • K Offline
      KDSDESIGN
      i recently installed win7 on my laptop. sketchup worked fine in xp, but now whenever i try to save or open or simply start a new model, it freezes up and crashes. can someone help?
      Regards,
      █Kevin█
      (about 20% done)
        Works fine on all the Win7 computers I've tried.
        My first guess is graphic card driver. What if you turn of Hardware acceleration, does it work then?
        Have you downloaded graphic card driver from the manufacturer, or do you use whatever Windows installed?
        What graphic card do you have.
        • K Offline
          KDSDESIGN
          im running it on a d610 (crap/old) but su worked fine before. i am using the model with the x300 card.
          su worked fine before win7 and everything other than su works right now.
          btw i tried everything in the hardware accelerator. i tried turning off aero. still doesnt work.
          Regards,
          █Kevin█
          (about 20% done)
          • E Offline
            ericschimel
            Try hardware acceleration, this will indicate if you are having a driver issue...
            Windows 7, in my limited experience, does a pretty decent job at going out and finding drivers automatically.
            In the case of my video driver, it did find the correct one, but I actually found a slightly new version when I downloaded it manually. Even though your video appears to be working properly, it may be prudent to manually seek out the driver.
            -Eric
            http://plugin.sketchthis.net
            Sketchup Kitchen Design Plugin
            Custom Models
              ScottPara
              I am running SU on a Windows 7 Enterprise build and it works great. Not sure on the issue but I would tend to agree it sounds graphics related. Try going back one or two drivers and see if you can find a more stable solution. We did have to do that.
              Scott
              Love the fact that some HATE my avatar.....
              • K Offline
                KDSDESIGN
                thanks. i wont need to update drivers im getting my computer replaced. just wanted to make sure it wasnt the OS
                Regards,
                █Kevin█
                (about 20% done)
                • EscapeArtistE Offline
                  EscapeArtist
                  Out of curiosity, did you try running it in XP compatibility mode?
                  • K Offline
                    KDSDESIGN
                    can't. you need a VT Compatible processer. i even tried to hack it. i only have a 1.86ghz pentuim m
                    Regards,
                    █Kevin█
                    (about 20% done)
