    Plugin to replace an instance groupe
    6 Posts 3 Posters 987 Views 3 Watching
    • 3 Offline
      3dsmax9
      I am looking for two scripts:
      the first script that allows me to select an instance of a groupe and replace it by another groupe
      the second that I saw a long time ago who start the move tool in copy mode (the move tool start with the littel plus witch indicate the copy mode)
        If you convert the group into a component you can replace it like you do with components from teh component browser. no plugin needed.
        But you can also use this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=26008
        lets you replace selected groups/components with whatever group/component you click on.
        Not a plugin. Just press Ctrl after activating the Move tool.
          btw: your profile:
          Operating system: p4 3ghz
          Operating System means Windows or OSX - nor your machine hardware
          • 3 Offline
            3dsmax9
            for the move tool I know that ctrl activate the copy process but i want the copy mode activate wen i click on the move tool so the first option is copy and wen i want to move i click on ctrl
              Invoking Move starts with Move and then toggles to Copy with Ctrl etc.
              It can't [easily] be changed by scripting.
              I suppose you could have a 'tools observer' that watches for the Move tool staring up and then immediately runs a Windows key-simulation for Ctrl ??? But isn't it just 99% easier to press Ctrl - after all it's just under your left-hand ?????
              • 3 Offline
                3dsmax9
                this script already exists I used it, long ago and I try to find it.
