    How to model a carved finial
    10 Posts 5 Posters 802 Views 5 Watching
    • R
      raych
      Hello, everyone! I am new to Sketchup and am trying to figure out the best way to model the hand-carved part of the flame finial in the attached drawing. The finial is part of a Queen Anne highboy. Thanks in advance for your help.
      Ray
      The upper part (4-3/16) is the part in question.
        is it hollowed or fulled?
        • C
          chrisjk
          They are normally hand carved as here :-
          http://www.vermontwindsorchairs.com/index.php3?gallery=-25-Queen_Anne_High_Boy
          Chris
            Some idea by KitoRaupp 😉 (another videos on the same thema by the same author)
            [flash=425,344:3w1kdaj1]http://www.youtube.com/v/jjgviBwP0L0&hl[/flash:3w1kdaj1]
            another way
            2 faces + Path (of course you take another faces than a complet circle 💚
            a crescentmoon for exemple 😉
            • C
              chrisjk
              There is more recent advice and more relevant on twists here:-
              http://forums.sketchucation.com/viewtopic.php?f=79&t=26031
              This is a very rough one I did using Fredoscale (twist then taper) The bottom part can of course just be lathed.
              Chris
              • numbthumbN
                numbthumb
                Hello there,
                You can find some "twisting" advices here
                http://forums.sketchucation.com/viewtopic.php?f=79&p=22430
                and here
                http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&p=203876&hilit=chain#p203748
                Some scaling would also be necessary in order to accomplish such a spiky form, at least I think so.
                Edit: sorry, wrong link. What I meant was http://forums.sketchucation.com/viewtopic.php?f=79&t=26031&p=224249&hilit=twisted+bar#p224220
                Comfortably numb...
                • C
                  chrisjk
                  A somewhat better one:-
                  Made using TIG's Extrude Edges by Rails plugin then tapering and twisting with Fredoscale.
                  Chris
                  • R
                    raych
                    Thank you everyone for all of the ideas and advice! This was my first post, and I am very impressed by all the responses. I will try out these methods for myself and I feel certain that I will find something that works here.
                    On another note: how can I update my profile to include my "Location"?
                    Thanks.
                    • GaieusG
                      @raych said:
                      Thank you everyone for all of the ideas and advice! This was my first post, and I am very impressed by all the responses. I will try out these methods for myself and I feel certain that I will find something that works here...
                      Yeah, those folks seem to be very helpful - thanks guys! 👍
                      Go to the User Control Panel (top left of the page) Profile Tab. You can make a whole lot of settings there, not only location. Browse through all the horizontal tabs and the vertical menus on the left.
                      • C
                        chrisjk
                        Here's one to play with. The model is too heavy as it stands and it also needs scaling.
                        Flame finial.skp
                        Chris
