    How to model a carved finial
    10 Posts 5 Posters 802 Views 5 Watching
      raych
      Hello, everyone! I am new to Sketchup and am trying to figure out the best way to model the hand-carved part of the flame finial in the attached drawing. The finial is part of a Queen Anne highboy. Thanks in advance for your help.
      Ray
      The upper part (4-3/16) is the part in question.
        is it hollowed or fulled?
        • C
          chrisjk
          They are normally hand carved as here :-
          404 Not Found
          (www.vermontwindsorchairs.com)
            Some idea by KitoRaupp 😉 (another videos on the same thema by the same author)
            [flash=425,344:3w1kdaj1]http://www.youtube.com/v/jjgviBwP0L0&hl[/flash:3w1kdaj1]
            another way
            2 faces + Path (of course you take another faces than a complet circle 💚
            a crescentmoon for exemple 😉
            • C
              chrisjk
              There is more recent advice and more relevant on twists here:-
              http://forums.sketchucation.com/viewtopic.php?f=79&t=26031
              This is a very rough one I did using Fredoscale (twist then taper) The bottom part can of course just be lathed.
              • numbthumbN
                numbthumb
                Hello there,
                You can find some "twisting" advices here
                http://forums.sketchucation.com/viewtopic.php?f=79&p=22430
                and here
                http://forums.sketchucation.com/viewtopic.php?f=323&t=23616&p=203876&hilit=chain#p203748
                Some scaling would also be necessary in order to accomplish such a spiky form, at least I think so.
                Edit: sorry, wrong link. What I meant was http://forums.sketchucation.com/viewtopic.php?f=79&t=26031&p=224249&hilit=twisted+bar#p224220
                Comfortably numb...
                • C
                  chrisjk
                  A somewhat better one:-
                  Made using TIG's Extrude Edges by Rails plugin then tapering and twisting with Fredoscale.
                    raych
                    Thank you everyone for all of the ideas and advice! This was my first post, and I am very impressed by all the responses. I will try out these methods for myself and I feel certain that I will find something that works here.
                    On another note: how can I update my profile to include my "Location"?
                    Thanks.
                    • GaieusG
                      @raych said:
                      Thank you everyone for all of the ideas and advice! This was my first post, and I am very impressed by all the responses. I will try out these methods for myself and I feel certain that I will find something that works here...
                      Yeah, those folks seem to be very helpful - thanks guys! 👍
                      Go to the User Control Panel (top left of the page) Profile Tab. You can make a whole lot of settings there, not only location. Browse through all the horizontal tabs and the vertical menus on the left.
                      • C
                        chrisjk
                        Here's one to play with. The model is too heavy as it stands and it also needs scaling.
                        Flame finial.skp
