    Arroway textures on Vray for SketchUp?
    renderpluginsextensions
    4 Posts 2 Posters 2.7k Views 2 Watching
    • H Offline
      hetauma
      Can someone help me with the values on the reflection maps on arroway textures?
      On their site they say :
      s050: "The specularity map; the recommended strength is 50%."
      (g025) "Instead of a map, you may specify a fixed glossiness value of 25%."
      So if I just want to use the second option and I have a material with g100 I just add a reflection layer which by default has Highlight Glossiness and Reflection Glossiness 1?
      but what happens when the value is g025?
      also what about the specular map? where do I load that? On the Maps at the reflection? or somewhere inside the reflection layer options?
      Thanx in advance
        yes.
        You set the glossiness to 0.25.
          Have you checked out the Arroway FAQ? http://www.arroway-textures.com/en/faq/14
          • H Offline
            hetauma
            yes that's where I copied and the 2 lines on my first post.
            Thanks very much for the quick answer!
