    SU crashes when starting VRAY 1.48.66 render
    renderpluginsextensions
    5 Posts 4 Posters 1.9k Views 4 Watching
      MartinPh
      This afternoon I purchased and installed the new VRAY after having used the demo of the old version to great satisfaction, and without any problems. I have attempted to make several renders, using simple default settings. However, each and every time SU shuts down completely a few minutes after the start of the render process, and I get a bugsplat message.
      Have I just wasted $800...!!??
      I noticed that after installing the new VRAY a number of pop-ups flash by very quickly when SU starts (way too fast to read them, you can just see the outline of the window before it disappears again).
      Are there known issues with this new edition of VRAY, or am I just having bas luck? I do hope there is a way to solve this!
      (P4, dual core, 2.133 Ghz, 4 GB ram, Nvidia Geforce LE videocard)
        jchau2007
        did you uninstalled the demo version? As Thom mentioned previously,you have to fully uninstall the old version before you install the new. Maybe this will have solve your problem.
          MartinPh
          That's a quick response jchau, thanks!
          But yes, I fully uninstalled the previous version. Meanwhile, after the first panic has abated a bit, I have found that the problem has to do with the size and complexity of the model I'm trying to render. Simple scenes render perfectly without a glitch. But the model I want to render is a 40 MB monster (and still growing), so there seems to be a memory issue there. Still, that very same model rendered without a problem in the older version of VRAY.
            I'm going to refer to the reply I made in your other thread: http://forums.sketchucation.com/viewtopic.php?f=11&t=26036&p=224447#p224447
              dedmin
              I also had this experience with the new demo version. Su started slow and the GUI of the V-Ray responded very slow and caused SU's freezing! I uninstalled it completely to get my SU back in shape! Nice render, but the GUI is very crowded and too uncomfortable.
