    [Plugin] Material Replacer
    77 Posts 41 Posters 85.2k Views 41 Watching
      @tig said:
      Like with Entity Info... my tool swaps the material but keeps the UV-mapping - so any rotated or scales/skewed textures stay unchanged, but the material uses a different image-file...
      Will this affect Twilight metadata? If I change a "wood" material with a "metal" material, both with textures... will it render as "metal", or just the image is changed and uses metadata from initially "wood" ?
      You could always try it yourself... πŸ˜’
      A Twilight material is associated with a SKP material.
      If you have a gray RGB material in your SKP you can tell Twilight to substitute it with a silver metal - shiny/textured/etc.
      If you have a buff RGB material in your SKP you can tell Twilight to substitute it with a golden metal - shiny/textured/etc.
      If you swap around materials in your SKP it'll be reflected in corresponding changes in the next Twilight render.
      How would changing a face's material in the SKP NOT affect the Twilight render? AND how might it affect the Twilight material - which is associated on a one-to-one relationship - gray=silver, buff=golden etc?? It only swaps around SKP materials by name it doesn't redefine them or rename them. I'm not sure what happens if you swap the names of materials over in your SKP - presumably if you said in the SKP material Browser gray=>gray1 and buff=>gray and gray1=>buff, then if Twilight uses a material-name look up table for how to render each of its materials based the SKP's current material-names then it would indeed swap what was silver with golden and vice versa... Perhaps useful on occasion, but not the point of this current discussion or thread.
      So to recap, swapping a face's SKP material gives the face that other SKP material, the face's material's UV-mapping comes from the face itself; whatever 'correspondence' Twilight a material has with the SKP material is kept intact and it renders accordingly...
        samyell77
        Hi thomthom,
        Love this plugin by the way. Is it possible to have the material name display whenever using the eyedropper tool and not just when running your ruby script. Having the name of the material display is SOOOO handy and I'd love it if the eyedropper always displayed the material name. Is this possible? I work on mac so currently trying to work out what material is what is pretty tricky due to the absence of a list view in the material browser. Also would it be possible to move the 'material replacer' to a context menu so you could access if using a right click rather than going to the drop down menus?
        Fantastic tool tho - thanks!
        Sam
        SU Pro 2016
        Dell Precision M4800
        PC Windows 10
        Intel Core i7-4900MQ @ 2.80ghz
        Nvidia Quadro K2100M
        16gb RAM
          I can't modify the native SketchUp tools I'm afraid.
          As for context menu, I could, but then someone would ask me to reverse it. But I'll see if I can send you a modified version.
            samyell77
            Would really appreciate that - thanks! πŸ˜„
            SU Pro 2016
            PC Windows 10
            16gb RAM
              samyell77
              Hey Thomthom - don't worry about sending the revised ruby. I hadn't realised that I can invoke plugins using key commands so have set up a keyboard short cut to your material replacer now. Thanks
              SU Pro 2016
              PC Windows 10
              16gb RAM
                rachitect
                Does this work with SketchUp 8 Pro? I copied the unzipped files into the SketchUp Ruby folder but it is not showing up in the Plugins menu in Sketchup... πŸ˜•
                  You don't see it there because it's not in the 'Plugins' menu!
                  It's in the 'Tools' menu - as 'Material Replacer'...
                  πŸ˜’
                    MartinK
                    Thanks for a great time saver. πŸ‘
                      caronte01
                      thanks Thomas, I use this plugin a lot!
                      • McGyverM Offline
                        McGyver
                        Thank you very much for this extremely useful tool! I Just tried it out and it works smoothly and without any trouble! Thank you!
                        Visit My ShareCG Freebie Gallery
                        • F Offline
                          fullyfledgeded
                          Hi, great simple little tool works perfectly, except the material being replaced, did not inherit the same scale of the texture. Any ideas?
                          thanks
                            LesZautres
                            This plug-in does exactly what I expected through a really nicely made UI!
                            Many thanks!
                            • NithinN Offline
                              Nithin
                              I think this plugin can be updated to make this function possible.
                              More details:
                              window frames with different sizes say 4'x3', 2'x3, 5'x2' are present which has same wooden texture(teak). Using this plugin if 4'x3' selected as source material then all other group/model with same dimension(ultimately volume) can be replaced with other material(oak) and other frames should remains unchanged.
                              • NithinN Offline
                                Nithin
                                Hi Thom,
                                with a little guide from TIG here, I manage to update this plugin.
                                I have no knowledge about ruby , not even a basic grammer 😞 , but as I am familiar with other languages like php and C++ , I just gone through the some ruby resources and made this modification.
                                Some minor changes is required as when trying to replace the default material , it is replacing whole model.
                                I am attaching both modified code and skp test file, hope you rectify this minor bug πŸ‘ .
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=55340
                                default material change bug using Material Replacer(Mod)
                                • tt_suT Offline
                                  tt_su
                                  Thanks. I've added an issue in the BitBucket repo to remind me to merge this: https://bitbucket.org/thomthom/material-replacer/issue/1/merge-user-fix
                                  • MrMitchellM Offline
                                    MrMitchell
                                    I have been exploring the Thea for Sketchup latest build on my Mac at work using SketchupPro2014 and was just playing around with the Thea Materials and Material Replacer this morning and think I have run into a serious problem.
                                    I had just added some of the default materials from the Thea library to the sketchup material library and had applied them to some of the components I had been working with earlier.
                                    I had applied the materials to the whole components instead of the faces of the components on some, while going inside of the components and adding the materials directly to the faces of the objects on others.
                                    I then drew a rectangular plane next to the models to pull the default material color from.
                                    Next I successfully used the material replacer to replace the materials applied to the components as a whole from their Thea Material (which was one of the default wood materials) back to the default white/blue sketchup material from the rectangular plane I was pulling from.
                                    However when I attempted to replace the materials inside of the components where the faces had been directly painted (using the example 01.mat.thea inside the displacement folder in the Thea Material Library) sketchup hung up.
                                    I force quit the program expecting to simply reopen the file, or at least even an earlier version of the file, but to no avail. All I get now when trying to open the file is this error message
                                    http://i.imgur.com/R10bA0S.png
                                    I even used Time Machine, which pulled versions of the files created earlier... same problem... Could you please shed some light as to how this problem could have occurred, or how I might be able to recover my files?
                                    -Thanks
                                    • tt_suT Offline
                                      tt_su
                                      Can you upload or PM the file in question?
                                      Does the backup file work? (the one with the tilde)
                                        MrMitchell
                                        Here are the corrupted files. Thankfully I had exported the file as an .obj to render and was able to convert the .obj to a .dae and recomponantize the model back in sketchup... but still... pretty scary.
                                        14016 Salter.skp
                                        AutoSave_14016 Salter.skp
                                        14016 Salter~.skp
                                          MrMitchell
                                          None of the files work. Even when I attempted to recover the files using Time Machine, the restored files still were treated like the corrupted files currently in the folder. Here are the recovered files, from the previous evening in case you want to try and poke at them...
                                          14016 Salter.skp
                                          14016 Salter~.skp
                                          • romboutR Offline
                                            rombout
                                            @thomthom said:
                                            When I use paint bucket tool to change the material on some object, the UV is reset.
                                            Use the Entity Info to replace materials - then the UV is preserved.
                                            Ive used UV textures to uvmap a mesh, is it still possible to replace the material. It keeps messing up the uv cause the base textures have different scale settings. I have the same material 3times, but they all have different settings though
                                            • 3 / 4
