    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Looking for a script
    9 Posts 4 Posters 969 Views 4 Watching
    • P Offline
      Panga
      Hi all,
      I'm looking for a script able to insert a component at each vertex of all objects in selection...I'm pretty sure that this script exists, but did not success to find it, don't remember the name.
      Thanks in advance !!
      Regards.
      Panga.
      • numbthumbN Offline
        numbthumb
        Hm... Component Spray 1.3 has the option to drop component at each vertex of selected faces.
        Comfortably numb...
        • P Offline
          Panga
          Thanks for the answer, but I have also edges in my selection...I have a script that puts a guidepoint at each vertex, but theses are not components...I'm still searching...Any other ideas ?
            Component Stringer can put a component at a vertice
              Try this
              require 'sketchup.rb'
              def placecomponentsatvertices()
                # select a component-instance and some faces/edges
                # the component is placed at each vertex...
                model=Sketchup.active_model
                ents=model.active_entities
                ss=model.selection
                instance=nil
                verts=[]
                ss.each{|e|
                  verts<< e.vertices if e.class==Sketchup;;Face or e.class==Sketchup;;Edge
                  instance=e if e.class==Sketchup;;ComponentInstance
                if instance and verts[0]
                  defn=instance.definition
                  verts.flatten!
                  verts.uniq!
                  points=[]
                  verts.each{|v|points<< v.position}
                  points.each{|p|
                    tr=Geom;;Transformation.new(p)
                    ents.add_instance(defn,p)
                else
                  UI.messagebox("Select a Component-Instance and some Edges/Faces...")
                  return nil
                end#if
              Copy the text into a file called placecomponentsatvertices.rb in the ../Plugins/ folder.
              Select a component-instance and some faces/edges...
              Type placecomponentsatvertices + <enter> in the Ruby Console.
              The component is placed at each vertex...
              πŸ€“
              You can add a menu item yourself... πŸ˜‰
                Component sprays by Didier Bur makes that
                What's new in 1.3.:
                New "shape" option to drop component at each vertex of selected faces.
                • P Offline
                  Panga
                  Component stringer...this is the one I was thinking of !!! Thanks for the info Pilou.
                  Thanks a lot for your piece of code Tig, I'm gonna try it πŸ˜‰
                  EDIT : It works like a charm...now I just have to learn how to create the menu item !! Something I always wanted to do this in order to organize all my plugins !! Any clue to acheive this ??? Not a solution, I want to learn how to do this.
                  Regards.
                    if not file_loaded?(__FILE__)
                        titletext="menuTextGoesHere"
                        UI.menu("Plugins").add_item(titletext){defNameGoesHere()}
                        cmd=UI;;Command.new(titletext){defNameGoesHere()}
                        cmd.status_bar_text=titletext+" someInstructionTextGoesHere"
                        ### you could put optional toolbar stuff here using 'cmd'...
                    file_loaded(__FILE__)
                    This code goes at the end of the file outside of the def...end...
                    Using the __FILE__ method lets you call the ruby anything you like...
                    • P Offline
                      Panga
                      Thanks a lot Tig. I'll give a look tonight at home.
                      Regards.
