    I want to be in a specific layer
    6 Posts 4 Posters 440 Views 4 Watching
    • P
      Pauline01
      hello,
      I work with layer in my plugin.
      I create an object, this object must be put on a layer.
      I want to be in a specific layer, and not just put visible=false or true.
      See in my code after :
      #I have 3 layers:"Layer0", "Batiment" and "Gestion de zones", i hide "Batîment"
      #I want to be in the layer "Gestion de zone" to create my object
      #here "Batiment" is just hidden but i don't arrive to be in the layer "Gestion de zone"
      thx.
      model=Sketchup.active_model
              #I have 3 layers;"Layer0", "Batiment" and "Gestion de zones", i hide "Batîment"
      	layers = model.layers
      	layers.each { |e|
      	name=e.name
      	if name.to_s == "Batiment"
      		e.visible=false
      	if name.to_s == "Gestion des zones"
      		e.visible=true
      		$gestion_zone_activation=1
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [30, 0, 0]
        pt3 = [30, 0, 17]
        pt4 = [0, 0, 17]
        coordinates = [0, 0, 8.5]
        # Call methods on the Entities collection to draw stuff.
        # new_face = entities.add_face pt1, pt2, pt3, pt4
        group = entities.add_group
        point = Geom;;Point3d.new coordinates
        group.entities.add_face(pt1,pt2,pt3,pt4)
      • thomthomT
        group.layer = model.layers['myLayerName']
        • P
          Pauline01
          I don't know if your function correspond at my question
          Maybe isn't possible, but i have the configuration of my layer like in the screen:
          http://i68.servimg.com/u/f68/14/78/18/60/first_10.jpg
          and i want arrive at:
          http://i68.servimg.com/u/f68/14/78/18/60/second10.jpg
          • J
            Jim
            Do you mean selecting the active Layer?
            Sketchup.active_model.active_layer = the_layer
            • thomthomT
              Are you changing the active layer because you want to put the geometry you create on that layer?
              • TIGT
                It's almost always best to leave the active layer as Layer0 and simply assign other layers to things as you make them...
                You usually wan to leave 'raw geometry' [edges/faces] on Layer0 - you can then set other layers for Groups/Component_Instances/Text etc to control their visibility...
