    I want to be in a specific layer
    6 Posts 4 Posters 352 Views 4 Watching
      Pauline01
      hello,
      I work with layer in my plugin.
      I create an object, this object must be put on a layer.
      I want to be in a specific layer, and not just put visible=false or true.
      See in my code after :
      #I have 3 layers:"Layer0", "Batiment" and "Gestion de zones", i hide "Batîment"
      #I want to be in the layer "Gestion de zone" to create my object
      #here "Batiment" is just hidden but i don't arrive to be in the layer "Gestion de zone"
      thx.
      model=Sketchup.active_model
              #I have 3 layers;"Layer0", "Batiment" and "Gestion de zones", i hide "Batîment"
      	layers = model.layers
      	layers.each { |e|
      	name=e.name
      	if name.to_s == "Batiment"
      		e.visible=false
      	if name.to_s == "Gestion des zones"
      		e.visible=true
      		$gestion_zone_activation=1
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [30, 0, 0]
        pt3 = [30, 0, 17]
        pt4 = [0, 0, 17]
        coordinates = [0, 0, 8.5]
        # Call methods on the Entities collection to draw stuff.
        # new_face = entities.add_face pt1, pt2, pt3, pt4
        group = entities.add_group
        point = Geom;;Point3d.new coordinates
        group.entities.add_face(pt1,pt2,pt3,pt4)
        group.layer = model.layers['myLayerName']
          Pauline01
          I don't know if your function correspond at my question
          Maybe isn't possible, but i have the configuration of my layer like in the screen:
          http://i68.servimg.com/u/f68/14/78/18/60/first_10.jpg
          and i want arrive at:
          http://i68.servimg.com/u/f68/14/78/18/60/second10.jpg
            Jim
            Do you mean selecting the active Layer?
            Sketchup.active_model.active_layer = the_layer
              Are you changing the active layer because you want to put the geometry you create on that layer?
                It's almost always best to leave the active layer as Layer0 and simply assign other layers to things as you make them...
                You usually wan to leave 'raw geometry' [edges/faces] on Layer0 - you can then set other layers for Groups/Component_Instances/Text etc to control their visibility...
