    Shortcut to deselect everything ?
    4 Posts 3 Posters 4.5k Views 3 Watching
    • H Offline
      haynesc
      hi all
      is there a way to create a shortcut to deselect and close all open groups and components ?
      i know you can select the model from the outliner dialog ... is there a way to create a keyboard shortcut for this or a little ruby?
      thanks
        Aerilius
        ctrl T = deselect everything (I don't know if it closes groups and components)
        ctrl A = select everything
          @haynesc said:
          hi all
          thanks
          First you need to be editing a group/component.
          Next you open Window > Preferences and click on Shortcuts
          Now in the filter window type close.
          You should see Edit/Close Group/Component.
          Select it and add you preferred shortcut to it - I use Alt+B.
          From now on pressing Alt+B will close the current edit session - if you are nested into edit a number of levels then repeat the key until you are back at the Model level...
          To assign a shortcut that is context specific first get that context, then filter to find it - e.g. hiding the rest of the model toggle on/off when editing is also very quick and useful as a shortcut... or you can select a face and then Reverse or Orient become available for shortcutting - these are both useful too... πŸ€“
          • H Offline
            haynesc
            @tig said:
            @haynesc said:
            hi all
            thanks
            thanks thats what i need πŸ˜„ ... i used Alt+Q (Q for Quit)
