    Degrees?
    4 Posts 3 Posters 430 Views 3 Watching
    • F Offline
      fhenaux
      Does any one know of plugin where I can dimension up radiused corners?
      Fred
      • Jean LemireJ Offline
        Jean Lemire
        Hi folks.
        If you want the radius of a round corner, the Dimension Tool will give you that, straight out of the box, when you use it on an arc or a circle.
        Just ideas.
        • F Offline
          fhenaux
          Thanks Guys,
          That's great.
            Radial dims are built in but for angular dimension see here http://forums.sketchucation.com/viewtopic.php?f=15&t=21730&st=0&sk=t&sd=d&hilit=angular+dimension&start=15 🤓
