    Help with Animation
    23 Posts 7 Posters 3.9k Views 7 Watching
      MartinRinehart
      I'm trying to figure out Animation.
      I understand how to implement an interface, I think.
      class Jumper
          def nextFrame( view )
              puts Time.now() - $start
              return ( Time.now() - $start ) < 15
          def stop()
              puts 'emptying trash'
      end # of class Jumper
      But I don't understand View.show_frame(). Do I have to call show_frame() every time I want a frame? What's that "<" doing? Why does the code example assign a return to "status" when the doc says it returns nil?
      Now that I know the timer doesn't really work, I'm eager to get something that does.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • Chris FullmerC Offline
        From the Docs:
        If nextFrame returns false, the animation will stop.
        The "<" is evaluating the statement on the left compared to the one on the right. It will return false after the animation has been running for 15 seconds. While it returns tre, the animation plays on. Once it returns as false, the animation stops.
        And I don't recall off the top of my head, but I think that you do have to call showframe everytime you want to show the next frame.
        Chris
        All my Plugins I've written
          Jim
          It's a typo. It's just:
          status = view.show_frame(delay)
            ? I'm confused. What line of code are we talking about?
              Jim
              I thought the API docs for show_frame.
                Ahhaaha! Sorry, I was in the wrong place I think. I was looking in the animation class Docs and only at his script example. The only "<" I saw was in his example, and that is clearly what I was explaining, which I thought was odd to have to explain.
                Yes, looking at the View.show_frame method docs I see now what I think Martin is referring to with the mis-leading "<" symbol. I agree with Jim - typo. Jim's example is how I've succesfully used it.
                Chris
                  MartinRinehart
                  @chris fullmer said:
                  Ahhaaha! "<" I saw was in his example, and that is clearly what I was explaining, which I thought was odd to have to explain.
                  ... I agree with Jim - typo.
                  Odd. If you look above the "<", in the Arguments, you see "lt;" which I took to be a typo in a character entity, "<" which is what you need if you want "<" to appear in the doc. Someone went to some trouble to get that typo in there. Brain cramp, I guess.
                  Thanks for the help.
                    MartinRinehart
                    My first goal, today, was to get this thing to tick off 15 seconds and then take out the trash. Expected to get here before breakfast.
                    It's now mid-afternoon and still - no ticking. Can anyone suggest the two or three lines of code (I hope!) needed to get ticking?
                    Many thanks. (Factoid: show_frame() returns a reference to the View.)
                    # anim.rb
                    require 'sketchup'
                    class Jumper
                        def stop()
                    $start = Time.now()
                    view = Sketchup.active_model().active_view()
                    puts view
                    view.animation = nil
                      Jim
                      view.animation = Jumper.new
                      and probably setting it to nil will kill it immediately.
                      nil will kill, haha.
                        todd burch
                        Actually, the way the Google editor works for this online doc is that it takes the author's typing, and "html-ifies" it for display when you click "save". So, in this case, there was probably no extra effort involved in providing a bad example.
                          Jim's code seemed to do the trick. I had to drag the ruby console around to see the puts values get added. But they were getting putsed and at 15 seconds the clocked stopped and your trash emptied.
                          And try this with a group or component selected and it will raise that G/C up 1 unit per frame.
                          require 'sketchup'
                          class Jumper
                          		$gc.transform! $t
                              def stop()
                          $gc = Sketchup.active_model.selection[0]
                          vec = Geom;;Vector3d.new(0,0,1)
                          $t = Geom;;Transformation.new(vec)
                          $start = Time.now()
                            MartinRinehart
                            Making progress. Tick! One tick is better than none.
                            Could not duplicate, Chris. Could you repost the entire program? What I've got is missing a move!(). Thanx.
                              That snippet was my entire code, run through Jims Web Console. I did not use the .move! method, but instead a regular .transform!. But .move! would have worked fine too (assuming the group/component is not rotated or scaled).
                              So to run it, copy and paste all that into Jim's webconsole, select and component and click execute.
                              All it does is creates a transformation (by vector) uf up 1 inch. Then at each next_frame it applies that transformation to the group. And as you know, the animation runs for 15 seconds.
                                Here is a quick animation showing your code in action (no sound):
                                [flash=1004,675:2gdcctgr]http://chrisfullmer.com/forums/martin_jumper.swf[/flash:2gdcctgr]
                                  MartinRinehart
                                  Hooray! It's alive. (It's doing exactly what TIG said: relative moves contrary to everything that I've seen. But that's another issue.)
                                  You wouldn't be able to slow that down to one or two moves per second, would you? At full throttle on my slow machine that's climbing about 63 inches/second.
                                  Edit: never mind. I got it.
                                              $gc.transform! $t
                                              view.show_frame( 0.5 ) # Really simple!
                                              return ( Time.now() - $start ) < 5
                                    Yes, that is where the .show_frame method comes in to play. Change your next_frame method to this:
                                    def nextFrame( view ) $gc.transform! $t view.show_frame 0.5 return ( Time.now() - $start ) < 15 end
                                    That puts a 0.5 second delay on the animation. That is how you can control the framerate for SU animations. Of course SU can run even slower than what you specify IF you are animating a lot of geometry.
                                    delay should equal seconds divided by framerate:
                                    delay = 1 / fps
                                    So a target of 15 frames per second is 1 / 15 = 0.066667 for the delay value:
                                    view.show_frame 0.066667
                                      MartinRinehart
                                      Here is a quick animation showing your code ...
                                      Very cool. "Our code" I think is more exact. And thanks!
                                      Hey, how did you do that? I'm thinking that my HTML tutorial is destined for treeware, but that doesn't rule out links.
                                        Also, the way I put in the transformation makes it move 1" each time the .next_frame method fires. So you would have to do some re-working to make it so that it moves 1" per second, regardless of how many frames get made during that second. But that is do-able, and frankly more useful than making it move 1" per frame.
                                        I think the way to do it would be to figure in the frames per second into the transformation, so when the user changes the frames per second, it adjusts the transformation vector distance. Just a thought,
                                        Chris
                                          View.average_refresh_time
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/view.html#average_refresh_time
                                          The average_refresh_time is used to set the average time used to refresh the current model in the view. This can be used to estimate the frame rate for an animation.
                                          This could be useful to verify you're getting the desired framerate?
                                            MartinRinehart
                                            Frame rate seems correct, within SketchUp's limits. Moves small things nicely at 24 fps. Flying my 50kB biplane smoothly. Corrects the timer problem.
                                            Will slow down, I assume (never assume!), if trying to move too much geometry.
                                            • 1 / 2
