    Help with Animation
    23 Posts 7 Posters 4.6k Views 7 Watching
      Jim
      It's a typo. It's just:
      status = view.show_frame(delay)
      • Chris FullmerC
        ? I'm confused. What line of code are we talking about?
          Jim
          I thought the API docs for show_frame.
          • Chris FullmerC
            Ahhaaha! Sorry, I was in the wrong place I think. I was looking in the animation class Docs and only at his script example. The only "<" I saw was in his example, and that is clearly what I was explaining, which I thought was odd to have to explain.
            Yes, looking at the View.show_frame method docs I see now what I think Martin is referring to with the mis-leading "<" symbol. I agree with Jim - typo. Jim's example is how I've succesfully used it.
              MartinRinehart
              @chris fullmer said:
              Ahhaaha! "<" I saw was in his example, and that is clearly what I was explaining, which I thought was odd to have to explain.
              ... I agree with Jim - typo.
              Odd. If you look above the "<", in the Arguments, you see "lt;" which I took to be a typo in a character entity, "<" which is what you need if you want "<" to appear in the doc. Someone went to some trouble to get that typo in there. Brain cramp, I guess.
              Thanks for the help.
                MartinRinehart
                My first goal, today, was to get this thing to tick off 15 seconds and then take out the trash. Expected to get here before breakfast.
                It's now mid-afternoon and still - no ticking. Can anyone suggest the two or three lines of code (I hope!) needed to get ticking?
                Many thanks. (Factoid: show_frame() returns a reference to the View.)
                # anim.rb
                require 'sketchup'
                class Jumper
                    def nextFrame( view )
                        puts Time.now() - $start
                        return ( Time.now() - $start ) < 15
                    def stop()
                        puts 'emptying trash'
                end # of class Jumper
                $start = Time.now()
                view = Sketchup.active_model().active_view()
                puts view
                view.animation = nil
                  Jim
                  view.animation = Jumper.new
                  and probably setting it to nil will kill it immediately.
                  nil will kill, haha.
                  • T
                    todd burch
                    Actually, the way the Google editor works for this online doc is that it takes the author's typing, and "html-ifies" it for display when you click "save". So, in this case, there was probably no extra effort involved in providing a bad example.
                    • Chris FullmerC
                      Jim's code seemed to do the trick. I had to drag the ruby console around to see the puts values get added. But they were getting putsed and at 15 seconds the clocked stopped and your trash emptied.
                      And try this with a group or component selected and it will raise that G/C up 1 unit per frame.
                      require 'sketchup'
                      class Jumper
                      		$gc.transform! $t
                          def stop()
                      $gc = Sketchup.active_model.selection[0]
                      vec = Geom;;Vector3d.new(0,0,1)
                      $t = Geom;;Transformation.new(vec)
                      $start = Time.now()
                        MartinRinehart
                        Making progress. Tick! One tick is better than none.
                        Could not duplicate, Chris. Could you repost the entire program? What I've got is missing a move!(). Thanx.
                        • Chris FullmerC
                          That snippet was my entire code, run through Jims Web Console. I did not use the .move! method, but instead a regular .transform!. But .move! would have worked fine too (assuming the group/component is not rotated or scaled).
                          So to run it, copy and paste all that into Jim's webconsole, select and component and click execute.
                          All it does is creates a transformation (by vector) uf up 1 inch. Then at each next_frame it applies that transformation to the group. And as you know, the animation runs for 15 seconds.
                          • Chris FullmerC
                            Here is a quick animation showing your code in action (no sound):
                            [flash=1004,675:2gdcctgr]http://chrisfullmer.com/forums/martin_jumper.swf[/flash:2gdcctgr]
                              MartinRinehart
                              Hooray! It's alive. (It's doing exactly what TIG said: relative moves contrary to everything that I've seen. But that's another issue.)
                              You wouldn't be able to slow that down to one or two moves per second, would you? At full throttle on my slow machine that's climbing about 63 inches/second.
                              Edit: never mind. I got it.
                                          $gc.transform! $t
                                          view.show_frame( 0.5 ) # Really simple!
                                          return ( Time.now() - $start ) < 5
                              • Chris FullmerC
                                Yes, that is where the .show_frame method comes in to play. Change your next_frame method to this:
                                def nextFrame( view ) $gc.transform! $t view.show_frame 0.5 return ( Time.now() - $start ) < 15 end
                                That puts a 0.5 second delay on the animation. That is how you can control the framerate for SU animations. Of course SU can run even slower than what you specify IF you are animating a lot of geometry.
                                delay should equal seconds divided by framerate:
                                delay = 1 / fps
                                So a target of 15 frames per second is 1 / 15 = 0.066667 for the delay value:
                                view.show_frame 0.066667
                                  MartinRinehart
                                  Here is a quick animation showing your code ...
                                  Very cool. "Our code" I think is more exact. And thanks!
                                  Hey, how did you do that? I'm thinking that my HTML tutorial is destined for treeware, but that doesn't rule out links.
                                  • Chris FullmerC
                                    Also, the way I put in the transformation makes it move 1" each time the .next_frame method fires. So you would have to do some re-working to make it so that it moves 1" per second, regardless of how many frames get made during that second. But that is do-able, and frankly more useful than making it move 1" per frame.
                                    I think the way to do it would be to figure in the frames per second into the transformation, so when the user changes the frames per second, it adjusts the transformation vector distance. Just a thought,
                                      View.average_refresh_time
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/view.html#average_refresh_time
                                      The average_refresh_time is used to set the average time used to refresh the current model in the view. This can be used to estimate the frame rate for an animation.
                                      This could be useful to verify you're getting the desired framerate?
                                        MartinRinehart
                                        Frame rate seems correct, within SketchUp's limits. Moves small things nicely at 24 fps. Flying my 50kB biplane smoothly. Corrects the timer problem.
                                        Will slow down, I assume (never assume!), if trying to move too much geometry.
                                        • renderizaR
                                          renderiza
                                          [flash=1004,675:rhvt88ob]http://chrisfullmer.com/forums/martin_jumper.swf[/flash:rhvt88ob]
                                          The code runs while using the “Ruby Web Console” but when I try to make a jumper.rb out of it to put it on the plugins folder the following error shows;
                                          Load Errors
                                          Undefined method ‘transform!’ for nil:NilClassError Loading File
                                          jumper.rb
                                          undefined method ‘transform!’ for nil: NilClass
                                          If I try to put the following;
                                          def transform
                                          $start = Time.now()
                                          The jumper.rb loads ok but when I press it no animations are triggered. Can someone please help me with this.
                                          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                                          • Dan RathbunD
                                            Dan Rathbun
                                            Load Errors
                                            jumper.rb
                                            Because the examples in this topic show very poor programming practice!
                                            (1) The code is not namespace protected
                                            (2) The code uses global variables that can conflict with other global variables.
                                            (3) There is no selection checking that prevents an exception if the selection is empty.
                                            (4) There is no entity Type checking to ensure that the selected entity(ies) can have the transform! method called upon them.
                                            I'll see if I can cobble up a better example, perhaps I'll post it in a new [ Code ] topic (so it can be indexed with the Code Snippet indexer.)
                                            I'm not here much anymore.
