    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Suppress warning Your recent operation...
    6 Posts 5 Posters 1.0k Views 5 Watching
    • X Offline
      xiobus
      Hey how do i suppress this warning from the user "Your recent operation has caused visible geometry to merge with existing geometry on a hidden layer" im running the bomb.rb script inside a program and it gives that warning message for each file/run it explodes
        I don't have the script but this is a general guide...
        Make a backup copy of the script as you might mess up!
        Open the script in Notepad.exe.
        Use its Find tool to locate the text Your recent operation or something similar.
        That line will probably look something like UI.messagebox("Your recent operation....")
        Add ### at the start of the whole line and it won't be executed...
        [ ### UI.messagebox("Your recent operation....")]
        Check for other instances of the text [or similar text] in case it is called by several tests..
        Save the script and run a test SKP - it should now NOT put that message up...
        ๐Ÿค“
          TIG, I think it's a native SU warning, not a ruby script warning. So I'm not sure if that can be suppressed at all...
          • Al HartA Offline
            Al Hart
            From your description, I am guessing you are running bomb from inside another ruby script, after hiding some layers. Try putting the geometry you are trying to modify into a group, before running bomb, and open the group for edit, so that bomb only operates on the geometry in the group. That might avoid the conflicts with other geometry on hidden layers.
            Al Hart
            IRender nXt from Render Plus
              Well, in that case it can't be suppressed... it's there for a reason ๐Ÿ˜’
              • Dan RathbunD Offline
                Dan Rathbun
                If the warning is sent to the console via STDERR, you may be able to suppress it by changing the setting for $VERBOSE.
                See this post in the Optimization thread.
                http://forums.sketchucation.com/viewtopic.php?f=180&t=25305#p217508
                If it's a viewtip or a messagbox in a .rbs, well ...
                I'm not here much anymore.
