    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 961.9k Views 175 Watching
      tiagomedeirosdsg
      Obrigado pelo plugin
        Thanks for [the] plugin
        • olisheaO Offline
          olishea
          For some reason, when I install this plugin....my sketchup starts up very quickly. I used to wait 15 seconds or so for all my plugins to load, now it's instant!!
          confused!!
          having a play with these amazing tools, thank you so much TIG.
          are there any videos in the pipeline? I feel they would help a lot.
          Also, how do you define a "melding profile"....I mean I know what it does.....is it just the finishing profile? if that makes sense
          oli
            Oli
            There are quite a few [illustrated] pages for each tool in the set - see the many links from the main zipped set download page...
            A lot of the tools need two profiles and two rails.
            The pick order is:-
            A 'profile' - the starting curve form that will 'extrude' down the rails.
            B 'rail-1' - the first rail to follow with this extrusion.
            C 'rail-2' - the second rail to follow with this extrusion - Note: you can also pick 'rail-1' again as 'rail-2' and it then assumes a copy of 'rail-1' is placed at the other end of the 'profile'.
            D 'melding-profile' [it's a fancy name for 'profile-2'!] is what the 'profile' will 'morph' into [meld] as it is repeated down the rails - Note: you can pick 'profile' again as the 'melding-profile' and then the only 'morphing' the profile will undergo is the fitting between the rails etc.The curves need not touch but it can be helpful to visualize the result if they do... the 'mesh' is made 'over' the 'rails'.
            Pairs of profiles/rails need NOT have equal curve segment counts... but if they do not and the numbers are not simple multiples then extra vertices are added to adjust the mesh and it might not be what you expected...
              maxel99
              excellent ruby tig, truly amazing.
              I just had two questions:
              *The extrude edges by faces does not appear to work with lines - can you make this work?
              A work around for this is to create a line and then break it apart and use the 'weld' ruby to put it back together. BUT is there a simpler way? It'd be great if this just worked for straight lines - or do you know of a similar ruby plugin that does this function?
              *second: are there tutorials for these tools? I am struggling to use them and it looks like there are bits and pieces of info on them but they are not in one central location - would it be possible to unify the tutorials for these into a few critical images for each tool like you unified the toolbar?
              Would be great, and as I said earlier, great tools as they are (just wish I could use them better with more tutorials!)
                It only uses Curves BUT as explained in it's notes you can have a single segment Curve made from a selected Line - use Divide > 2 and then Weld the still selected 2 parts to make a Curve, now draw another Line to split the Curve at it's center Vertex and erase one part. You now have a single segment Curve.
                It cannot use lone Lines as it would recognize each segment in a selected Curve as a Line - so it's all Curves I'm afraid - it's not too onerous to make Lines into 'straight' Curves - Tip: I use shortcuts for Divide [Ctrl+D], Weld [J] etc...
                • jeff hammondJ Offline
                  jeff hammond
                  maxel,
                  fredo's BezierSpline plugin:
                  http://forums.sketchucation.com/viewtopic.php?t=13563
                  ..can draw polylines (or one segment curves if you will) which work great with the extrude tools
                  either draw the lines in place (using 'polyline'.. the second icon in the toolbar) or, draw the lines with SU's line tool then right click it -> BZ Convert To -> polyline.
                  as to the tutorials, i'm pretty sure there isn't a consolidated list.. these are fairly new tools tig has developed and many of the early adopters are still learning them.. best thing to do at this time is post an example .skp here showing what you'd like to accomplish and someone will be able to tell you if it's possible or how to do it..
                  dotdotdot
                  • olisheaO Offline
                    olishea
                    cheers for explanation TIG, i just needed it in words!!
                    oli
                    • I Offline
                      InterArchi
                      Thank you sir for this script...
                      Can anyone here show us what did he do with this script in a real project, in a design work or in sketch project ?
                      I mean I know it is very great to work with thhis plugin, but I really want to see an architectural work made by this great plugin, Any one ?
                        jeff hammond
                        i have a bunch of concepts and construction drawings which i drew using these tools but i have to keep them off the web..
                        i've got an actual project beginning in 3 weeks which was designed using extrude by rails.. i'll post some pictures upon completion.
                        dotdotdot
                        • I Offline
                          InterArchi
                          Hi sir ..Still waiting for your post sir
                          • O Offline
                            ofarcan
                            thanks for plugin.
                              Here's an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              The 'extrudeEdgesByRailsToLattice' tool has been updated to include a pane-thickness option - useful if the pane might be viewed from both sides and/or exported to a 3rd party renderer where back-faces are not rendered. Also its .lingvo files have been updated to suit...
                                Here's an updated zip http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                The main changes are...
                                The 'Extrusion Toolbar' title's db() translation is fixed with a new lingvo file.
                                In EEbyVector you can now end an 'extrusion' in with a 'double-click'.
                                In EEbyFace if there is no 'suitable' face in the selection it's trapped with error message.
                                In EEbyLathe it now undoes in fewer 'steps' - ~one for each 'optional dialog'.
                                In EEbyRailsToLattice the missing db() on 'Processing...' in corrected.
                                  Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  ExtrudeEdgesByRailsByFace is now trapped to stop you selecting a non-flat face and breaking Sketchup!
                                  the lingvo files are also updated to suit.
                                    smiley007
                                    Thanks very much for these exellent tools.
                                      There a new tweak to EEbyRailsByFace to catch no face selected or an empty selection at the start [as well as any 'inappropriate' selections].
                                      Also two of the ES lingvo files have some minor rephrasing by Defisto [again!]...
                                        cdurkin
                                        Hello
                                        Ive just added the extrude tools zipped set to my ruby library but, despite getting the plugins to work on version 7, I'm having difficulty getting them to work with SU version 8. Has anyone else had the same problem??? know how to fix??
                                          cdurkin
                                          What error messages do you get at startup or later in the Ruby Console when you try to use the tool ?
                                          It works fine for most users in v8, if it's correctly installed.
                                          Hove you copied all of the required files and sub-folders over ?
                                          Make sure there are none in the wrong place too, even if you have done a full install from the zip you might have some files misplaced and causing clashes...
                                          Their has been one report of a clash with SketchyPhysics in v8 [I suspect that SP rewrites a SUp base-class method ill-advisedly that some EEby... (and other's) tools are using... but it's not yet established/resolved].
                                          If you have SketchyPhysics try removing its .rb files from Plugins temporarily and see if that fixes the glitch...
                                            cdurkin
                                            Hello again
                                            The Specific problem has to do with the icons on the toolbar and heading eg(extrude edges on edges ect.)on the menubar. Some of them work and others don't. It sounds like it may be the folder allocation problem you suggested. I have all files that came with the plugin in the the TIGtools folder accept the 10 extrudeEdgesByEdges.rb.......to...extrudeEdgesByVector.rb files which are directly in the plugins folder. The icons on the toolbar that seem to be giving my trouble are:
                                            extrudeEdgesByFace.rb
                                            extrudeEdgesByFaces.rb
                                            extrudeEdgesByRails.rb
                                            extrudeEdgesByRailsByFace.rb
                                            extrudeEdgesByRailsToLattice.rb
                                            I can use all the commands, it even says in the command prompt at the bottom of the screen the the geometry is being made, yet no matter how long i wait the extruded geometry does not appear.
                                            extrudeEdgesByLathe.rb
                                            extrudeEdgesByLoft.rb all work fine
                                            If it is the file allocation problem do you know which other files I should move?
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 31
                                            • 32
                                            • 9 / 32
