    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 867.4k Views 175 Watching
    • OxerO Offline
      Oxer
      Thank you very much TIG!! 👍
      Now the translations work fine again.
      http://www.oxervision.blogspot.com/
        mishgan
        hi,
        how can i download this plugin??? i don't see the zip file...
        • massimoM Offline
          massimo Moderator
            @mishgan said:
            hi,
            What Massimo said. Or you could download the RBZ file and install it automatically via Install Extension or, even better, install the Sketchucation Plugin Store and install it automatically that way.
            • I Offline
              iivvaann
              Hello. I have an error reboot after installing Extrude Tools v2.5 .:
              Error al cargar archivo C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb
              Error: #<LocalJumpError: unexpected return>
              C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb:33:in <module:ExtrudeTools>' C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools/ExtrudeToolsLoader.rb:23:in <top (required)>'
              C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
              C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:68:in register_extension' C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:68:in module:ExtrudeTools'
              C:/Users/Iván/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/ExtrudeTools.rb:29:in `<top (required)>'
                Your Windows user-name is Iván - with an accent !
                Prior to v2014 user-names containing accented characters were well known to cause issues with Ruby scripts - e.g. when using 'File' methods [you still show v8 in your user-profile, but the reported error is in v2014].
                This issue is improved in v2014... BUT such accents etc can still cause problems in FILE related code used by many scripts...
                I'll try coming up with a fix and reissue this toolset shortly - look for a new version later today...
                Let me know if it works...
                However, having an accented user-name WILL still cause issues with SketchUp pre-v2014... AND in several other toolsets' code in even v2014 too.
                  Here's v2.6 http://sketchucation.com/pluginstore?pln=ExtrudeTools
                  It is re-coded in an attempt to allow users who have accents in their Windows user-name to still successfully load and use the toolset in v2014...
                  • I Offline
                    iivvaann
                    Woo uuu !!! Excellent, it worked instantly. Thank you very much TIG, my laptop is new and the seller put the accent on the user name. I was already forming to not have this plugin. Thank you very much for taking the time to help me. Thank you again. Greetings.
                      Glad to be of help... 😄
                      If you get similar issues with other scripts, then please let the author know.
                      This kind of report is rare, but there are possible workarounds - at least for v2014...
                      • P Offline
                        Pherim
                        Extrude Edges by Faces by Rails makes my SU2015 64bit always crash immediately after finishing - it works fine on the same model in SU2013. No error message, just crash and bug splat window the second I click yes or no to erasing the original curves.
                        All other tools work.
                        It's amazing though, how much faster this and many other operations are executed in the new 64bit version.
                          Looks like we ought to continue this issue in this 'Extrusion Tools' thread ?
                          I'll investigate...
                          PS: I see the issue too, trying to see its cause 😕
                          • P Offline
                            Pherim
                            Your recommendation in the other thread made me try out every tool in this set, and that's how I discovered this issue.
                            Sorry for keeping you busy like this. 😉
                              Here's v2.7, now in the PluginStore
                              http://sketchucation.com/plugin/1103-extrudetools
                              The update covers ExtrudeEdgesByRailsByFace - it has been adjusted to work properly in v2015, which unexpectedly showed a glitch when calling another tool from within its mouse-click method...
                              As a 'side-effect' it also has some improved graphics, prompting etc...
                              • P Offline
                                Pherim
                                I confirm that it works now. Thanks!
                                • H Offline
                                  Hecky001
                                  Hello there i am here to report a crash of my sketchup 8 pro when using Extrude Edges by Rails by Face
                                  it crashes only when the profile its segmented more than 12 times for example if a segment a circle 13 times it will crash the sketchup a bug splat but when i segment circles below 12 it does the job fine can someone please tell me whats going on
                                    Manijeh
                                    I have just installed this plugin through plugin store tool bar's autoinstall.
                                    I watched the video on youtube and followed step by step. but the tools didn't work for me.
                                    Is there any way there could be a more detailed video tutorial preferably with audio?
                                    Also am I missing something in the operations and or installation of this tool?
                                    Thanks for your response.
                                    Manijeh
                                    • P Offline
                                      perper
                                      No toolbar
                                      Can anyone assist me?
                                      I have downloaded the TIG Extrude tools to SketchUp.
                                      Unfortunately I can not find the toolbar..
                                      Pls help
                                      Best regards
                                      Per
                                        @perper said:
                                        No toolbar.
                                        You said you downloaded the RBZ.
                                        You have NOT said you have installed it !
                                        So if you haven't...
                                        Window > Preferences > Extensions > Install... button...
                                        Choose the Plugin's RBZ and answer in the affirmative to any questions...
                                        NOTE: if you installed it with the SketchUcation PluginStore Toolset's dialog within SketchUp itself it should Auto-Install.
                                        Assuming it is installed...
                                        Look in the v2015 "Extensions" menu [called "Plugins" in ALL pre-v2015 SketchUps] for "Extrusion Tools..." submenu items...
                                        Are they there ?
                                        Also check that the "Extrusion Tools" Toolbar is activated...
                                        If none of this works come back. 😕
                                          logan683
                                          Sketchup 2015 Pro
                                          Whenever I extrude an edge, by any means, and save, it undoes the extrusion and will continue to undo every time I save. It acts just like Ctrl-Z whenever I hit Ctrl-S, and it crashes occasionally.
                                          Thank you. It was working fine.
                                            logan683
                                            Ok, I figured it out. Extrude Tools have a conflict with SUSolid plugin. I really need both. I am emailing the dev of SUSolid now. Is there anything I can send you to check on your end? Thank you.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 31
                                            • 32
                                            • 26 / 32
