    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 962.2k Views 175 Watching
      There should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
      It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as ' $extrusionToolbar' and an 'Extrusion Tools' submenu referenced as ' $extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder...
      Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
      Note that the EEby... tools also 'require' deBabelizer.rb ?
        Jim
        Ah, I renamed it without the #. Guess I can't do that.
          NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
          The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
          Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
          πŸ˜’
            Jim
            And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
            Thanks.
              Jim
              I made these mods to make it portable:
              starting @ ~ line 50
                  eePlugins.each{|plugin|
              	path = File.join(File.dirname(__FILE__), plugin+".rb")
              	#if Sketchup.find_support_file(plugin+".rb","Plugins/")
              	if File.exists?(path)
              	    gotPlugin=true
              	    break
              	end#if
                Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
                It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
                  > 	    gotPlugin=true
                  > 	    break
                  > 	end#if
                  I had just made very similar changes - you posted as I uploaded it - see updated set... πŸ˜’
                    Jim
                    Frequent updates are another advantage of using a shared Plugins folder! πŸ˜†
                    Thanks again.
                      I think I'm done for a while on updating this tool... πŸ˜’
                      • U Offline
                        unclex
                        Sorry , my mistake
                        the reason is another Plugins
                        Thanx for ur replied
                          manson666
                          I'm new Sketchup user
                          now learning it
                          I founded out sketchup plug in is strong tool
                          thx share
                          • O Offline
                            openhatch
                            If I haven't said this before, awesome tools, thx. πŸ‘
                            This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. 😞
                              I know about the SketchyPhysics issue - it can also affect other tools... http://forums.sketchucation.com/viewtopic.php?p=300111#p300111
                              The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
                              http://forums.sketchucation.com/viewtopic.php?p=300105#p300105
                                Destors
                                How i need to make these things, help me please πŸ˜„
                                http://pix.playground.ru/download/gallery/664241/e8dc3ff2a2429a9a221028809dbf41d6.jpg
                                http://pix.playground.ru/download/gallery/664241/f57318be4e038aa96c6285ff3df68a19.jpg
                                • O Offline
                                  openhatch
                                  Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
                                  • ? Offline
                                    [[global:former-user]]
                                    Thanks guys this is extremely good plugin that i was looking for so long
                                      doraemon79
                                      Wonderful tool....
                                        rock1
                                        this toolset is a bit complicated for usage for a novice like me. I'm getting some unexpected results. Are there any video tutorials πŸ˜’
                                        Signature removed by SCF Admin
                                        • majidM Offline
                                          majid
                                          ow... it jumps out of Sketchup with no error message!!! (almost half of tools!!!! eebe , eebf,eebfs, EEbR)
                                            Majid
                                            Have you installed any new Plugins lately?
                                            Try disabling them temporarily and see if that helps.
                                            Do you get any error messages in the Ruby Console before the 'crash'?
                                            If you do find the culprit let use know asap.
                                            πŸ˜•
                                            Have you tried repair/reinstall Sketchup and/or reinstalling the Extrusion tools again...
                                            This is weird πŸ˜•
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 31
                                            • 32
                                            • 12 / 32
