    Lock a layer
    6 Posts 4 Posters 11.8k Views 4 Watching
    • X Offline
      xiobus
      Any one know how to lock a whole layer? I only see in the API ability to lock groups and components and I also don't see a way to easily move entities into a group/component. Perhaps there is an efficient way to "copy, paste and delete" a list of entities or even copy from one group to another preferably based on selection or layer?
        MartinRinehart
        @xiobus said:
        ... I also don't see a way to easily move entities into a group/component.
        Tutorial, Chapter 13:
        def all()
            model = Sketchup.active_model()
            model.selection().clear()
            ents = []
            for e in model.entities()
                ents.push( e ) if e.layer().visible?()
            model.selection().add( ents )
        end # of all()
        Same source:
        def make_component( entities, name )
        =begin
        Given an array of entities and a name, returns a named component
        containing the entities.
        =end
            ents = Sketchup.active_model().entities()
            g = ents.add_group( entities ) # group all entities
            inst = g.to_component() # convert group to component instance
            inst.definition().name = name
            return inst
        end # of make_component()
        After all model.selection is an entities collection. This is the Ruby equivalent of pressing Ctrl+A and then keyboard G to make component.
        Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
          You can only 'Lock' Groups and Instances of Components.
          Sketchup Layers are not like CAD Layers !
          If you want to Lock everything on a particular SUp Layer you need to use Group-Entities-by-Layer - there is a script out there on this Forum to do that - use Search......
          Then you need to Lock that Group.
          This will not Lock Entities on that Layer if they are inside a Definition [i.e. Groups and Components].. but you can use Group-Definition-Entities-by-Layer and then Lock that Group - by iterating through the model.definitions.entities.each{|e|...}
          • Bob JamesB Offline
            Bob James
            In the Help for SU7 it discusses three icons in the Layers Dialog Box:
            Visibility Button
            Lock Button
            Share Button
            But the Dialog Box displayed is not what you get in SU7
            What am I missing?
              Read the path to the help section - it's for Layout - where you can lock layers !Capture.PNG You can't do it in plain Sketchup !
                Bob James
