    Newbie question
    8 Posts 3 Posters 459 Views 3 Watching
    • J
      Jed Sutter
      Hi-
      Brand new to Sketchup and to this forum. From the look of the posts I'm in expert hands.
      I'm interested in SU for woodworking. I just started drawing a bed frame to build. The other day a few of the faces of the footboard component changed color to a greyish, slightly darker color from the default tan after I'd edited the component. Can't seem to figure out why. It's not the dark grey found on the inside of a form. Almost looks like it is in shadow, even though it is on the lit side of the model.
      Any ideas?
      • GaieusG
        Hi Jed and welcome.
        Well, it can be many things from innocent to annoying - could you upload an example file (or at least an image/screenshot)?
        (Below the text area you answer, there is the attachment tab)
        • J
          Jed Sutter
          Oops, I should have thought an example would be helpful-
          I will upload the file as soon as I get to my home computer- thanks!
          • J
            Jed Sutter
            Here's the model attached. Thank you for the help!
            Jed(I just put some walls in to let the shadows fall on something)
            • GaieusG
              @tig said:
              It faces' 'inside is out'.
              Now that's a contradiction. Guys, at the end you make me download that model myself.
              πŸ˜„
              OK, downloaded and indeed, back faces. I believe all are oriented now correctly (and a bunch of faces were also missing).
              BTW you should make all repetitive elements components (legs, bed end pieces etc).
              bed with head-foot panels #2E.skp
              • J
                Jed Sutter
                Oh! I get it, even if I don't know how I did it. Thank you for the input, TIG and Gaeius. Gaeius, thank you very much for making the fixes. I did it on my end, too, to make sure I understood what you did.
                Best wishes,
                Jed
                • GaieusG
                  πŸ‘
                  You know, I don't like doing the job instead of others but when I saw it ready, I thought it would be so mean not to upload. πŸ˜„
                  But indeed, do it yourself to learn, too.
                  There is another topic right now about face orientation - you may find it interesting:
                  http://forums.sketchucation.com/viewtopic.php?f=79&t=25006
                  • TIGT
                    It faces 'inside out'.
                    Edit it and 'reverse' one or two faces, then select one face and 'orient' as they are all facing out...
                    Fixed.
