    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Is there a toolbar button for weld?
    12 Posts 8 Posters 2.2k Views 8 Watching
    • W Offline
      watkins
      I use this script a lot, and so it would be nice if it had its own toolbar button. Perhaps Rick could update the script to include a button?
      Kind regards,
      Bob
        dylan
        I use this a lot myself, probably my 2nd most used ruby.
        Mirror is by far the one I use most.
        I would use the button.
        http://dmdarchitecture.co.uk/
          Jim
          If you have weld.rb installed, this will make a toolbar. You'll need icons also - one 24x24px, the other 16x16px. See the code for the names of the image files.
          # weld_tool_button.rb
          pf = Sketchup.find_support_file("Plugins")
          if File.exists?(File.join(pf, "weld.rb"))
            cmd = UI;;Command.new("Weld") { join_edges }
            cmd.tooltip = "Weld"
            cmd.status_bar_text = "Weld"
            cmd.large_icon = File.join(pf, "weld_lg.png")
            cmd.small_icon = File.join(pf, "weld_sm.png")
            tb = UI;;Toolbar.new("Weld")
            tb.add_item(cmd)
            cmd = tb = pf = nil
            you can also make a shortcut ๐Ÿ˜‰
            It will be more speedy in use than a tool bar ๐Ÿ˜‰
            • kenK Offline
              ken
              The following toolbar has a weld icon
              Ken
              • W Offline
                watkins
                Dear Jim,
                Thank you for replying so quickly. Do I insert the program snippet into the text file for weld.rb, and if so, at what point should it be inserted? At the end?
                Presumably, the image files weld_lg.png and weld_sm.png would go in the plugin folder. Ideally, the images would go in to a separate folder called Weld, keeping everything together and well annotated. How could that be done?
                Thanks Ken! I know of the SCF Powerbar, but I would like just the one button.
                Pilou, yes you are right! A short cut would be quicker, but I rather like the idea of a button.
                Kind regards,
                Bob
                  Probably the path would be something like
                  "Weld/weld_lg.png"
                  "Weld/weld_sm.png"
                  I hope SM is not for sado-mazo ๐Ÿ˜ฎ
                    Jim
                    No, that s a stand-alone script. create a file named weld_toolbar.rb and paste the code in.
                    The toolbar will work without the images, but the buttons will be blank.
                    Gaieus is correct, if you want the images in a folder named weld, change these lines:
                    cmd.large_icon = File.join(pf, "weld", "weld_lg.png")
                      cmd.small_icon = File.join(pf, "weld", "weld_sm.png")
                      Hear, hear? I am correct!
                      ๐Ÿ˜
                      So Jim, what should my first plugin be? ๐ŸŽ‰
                        I use the shortcut J[oin] as it's the same in CAD... AND very quick - the N[o] key is just below it to cancel the dialogs too...
                        • W Offline
                          watkins
                          Thanks to all!
                            sergey2402
                            There is a toolbar button for weld
                            Jim, Gaieus - thanks!
                            Weld_button.rar
