    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Help!!! How to twist a rectangukar surface? Help!!!
    7 Posts 3 Posters 2.6k Views 3 Watching
    • H Offline
      HelloKeithy
      OK, i badly need help on this.
      How do i twist a rectangular surface?
      Basically, this rec. surface is adjacent from the top of the building that will make its way to the front part of the building (going down) to be a shed to the entrance part.
      Help. Thank You!!!
      This is the concept: (see attachment)
        Sigitas
        Hi HelloKeithy,
        I use the Sandbox tools, make the surface form contours line.
        • H Offline
          HelloKeithy
          Thank you so much. Is this also applicable with a mass on the object, meaning not just plain flat surface?
          • H Offline
            HelloKeithy
            the problem now is how to use the sandbox tool. hehehe...
              Sigitas
              draw the contour line
              select bouth and use sandbox tool contour from
              see at pic there is presented step by step.
              good luck.
              twist.skp
                You can use Fredoscale for twist anything πŸ˜‰
                or Shape Bender
                or Extrude Edges by 2 rails πŸ˜‰
                • H Offline
                  HelloKeithy
                  good luck.
                  THANK YOU!!! I'll try that...
