Help!!! How to twist a rectangukar surface? Help!!!
OK, i badly need help on this.
How do i twist a rectangular surface?
Basically, this rec. surface is adjacent from the top of the building that will make its way to the front part of the building (going down) to be a shed to the entrance part.
Help. Thank You!!!
This is the concept: (see attachment)
Hi HelloKeithy,
I use the Sandbox tools, make the surface form contours line.
Thank you so much. Is this also applicable with a mass on the object, meaning not just plain flat surface?
the problem now is how to use the sandbox tool. hehehe...
draw the contour line
select bouth and use sandbox tool contour from
see at pic there is presented step by step.
good luck.
You can use Fredoscale for twist anything
or Shape Bender
or Extrude Edges by 2 rails -
good luck.THANK YOU!!! I'll try that...
